Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Help, please. Ape Hanger Geometry - Any Ideas?
Old Jun 2, 2008 | 10:00 PM
BluBob's Avatar
BluBob
Default Help, please. Ape Hanger Geometry - Any Ideas?
I have a set of stock HD mini apes (10.25" rise and 6.5" pullback) with 4.5" risers under them. The stock cables fit fine, and I like the height. I want to go to a 1.25" ape bar that has the same geometry when mounted to stock 1.5" risers. So I am looking for a set of 1.25" OD apes with about a 13" rise. The problem is I see some listed with a rise of 13, but an end rise of 16". What is the difference in the measurements? I don't want to order the wrong set because they are pretty spendy to ship. The ones I am looking at are V-Factor Apes with these specs:
[ul][*]End Rise: 13 1/2 in.[*]Pullback: 9 in.[*]Rise: 16 in.[/ul]Again, I would mount these on 1.5" risers instead of the 4.5", so I would lose 3" in riser and gain it back in bars. Would they be about the same height at the controls as my 10.25" stocks mounted with 4.5" risers?
Old Jun 2, 2008 | 10:02 PM
anubisss's Avatar
anubisss
Default RE: Help, please. Ape Hanger Geometry - Any Ideas?
I imagine end rise would be the end of the bars where your grips go, but probably the very end. The total rise is 16" meaning at their highest point.
Old Jun 2, 2008 | 10:26 PM
BluBob's Avatar
BluBob
So I probably need to do a cable swap if I go with these V-Factors? Is there any slack in the stock cables I can take up if I remove the tank? Thanks. Really I need to get ahold of someone who has these bars and see what they needed for cable lengths.
gfroy91
Aug 1, 2014 05:04 PM
jhamm
Aug 21, 2012 11:48 AM
firebrick
Oct 15, 2009 07:46 AM
Brandons_Deluxe
Feb 18, 2009 08:05 PM
2StrongHayn
Aug 25, 2007 03:32 PM
