Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
speedometer cable removal
Old Jun 20, 2011 | 08:26 PM
skiparope's Avatar
skiparope
Stage I
Default speedometer cable removal
i have a 1993 FXDWG and the speedometer cable broke right at the wheel. my question is how do i get the small piece of the inner cable that broke off inside the drive unit? there wasn't a piece sticking out. do i have to take the wheel off to remove the drive unit or is there some kind of trick? i tried a magnet but nothing came out...... help?!!?
Old Nov 11, 2018 | 07:39 AM
Losde757's Avatar
Losde757
I'm undergoing the same right now. I see no responses. did you ever fish it out?..... I tried the magnet thing too, but to no avail. I'm about to strap it back together, plug the connection to the odometer and ride arouind the block, and hope like everthing else....it'll vibrate loose/out.
Old Nov 11, 2018 | 08:24 AM
bustert's Avatar
bustert
well, it broke for a reason.
you might try using a small drill bit using reverse rotation of the cable to see if it will loosen it up, the intent is not to drill it out! the square drive is probably wedged being it probably has rounded off with miles of use.
cjshovel
Shovelhead
Aug 28, 2013 02:06 AM
Lumpy Schmidt
EVO
11
Oct 6, 2012 02:51 PM
mballard
Shovelhead
Jul 5, 2012 05:28 PM
85RoadsterXLS
May 23, 2012 07:46 PM
z2008
Jul 6, 2008 07:42 PM
