Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Front end shakes over 100
Old Oct 27, 2012 | 01:24 PM
Nellie636's Avatar
Nellie636
2nd Gear
Default Front end shakes over 100
My 03 softail shakes like crazy anytime I go over a 100mph Unless I keep it fully cracked open. Is their a remedy to this or is it just me?
Old Oct 27, 2012 | 01:28 PM
EP50's Avatar
EP50
Yeah mine does too. It goes away though at 183. So I try and stay above that.
Old Oct 28, 2012 | 07:14 AM
NSCoyote's Avatar
NSCoyote
tire pressure, fork oil, tire life left, loose steerign neck, bad wheel bearings all could be a cause of it. my dyna tank slapped bad after 120-130kph, swapped the fork oil out to SE heavy oil replaced the rear tire wit ha metzler me880 and adjusted fall away and now i can hit the 180-190 mark with ease and even get on up over the 200 mark with jus ta few vibrations
Old Oct 28, 2012 | 07:19 AM
Stiggy's Avatar
Stiggy
I didn't know that a Softail could go over 100 mph...
Old Oct 28, 2012 | 07:34 AM
Iceman24's Avatar
Iceman24
Unless you're running the bike in 1/4-mile increments, why go that fast? My bike's meant for relaxing "cruising" - not drag racing. Fastest interstate speed to date is 85 mph so just keep it to the speed limit & you're good to go...
Old Oct 28, 2012 | 06:04 PM
SoCal TV's Avatar
SoCal TV
Stage I
Check your steeing head for looseness. Put the bike on a stand with the front wheel off the ground and see if you can move the fork slightly fore and aft. If so tighten up the steering head. Also the bearings could be rusted or worn if you pressure wash the bike.
Failing that, bikes can get headshake when the fork is to low in the travel. The frame geometry gets steeper when you're on the brakes That's why it goes away when you gas it. Fork oil level could be too low or the springs sacked out.
tholmes@holmespowersports.com
Old Oct 28, 2012 | 06:11 PM
jerryleon's Avatar
jerryleon
100 ? why ????
Old Oct 30, 2012 | 09:24 AM
grbrown's Avatar
grbrown
Front end things like that often start at the rear. Tyres are critical so check you have suitable pressures and if yours are worn, have got a flat band around them or are getting old, fit brand new top quality ones. If you want to go that fast use an alternative brand such as Avon.
shred1
General Topics/Tech Tips
Sep 21, 2016 06:27 PM
Sliver1
Jan 1, 2014 11:47 AM
MACHD03
Jan 30, 2011 01:09 AM
toaster
Feb 14, 2010 11:23 AM
bull346
Aug 27, 2008 10:21 AM
