Samson true duals troubles
Old Oct 13, 2014 | 12:18 AM
mayo92's Avatar
mayo92
4th Gear
Default Samson true duals troubles
I've been waiting on my Samson true duals and finally got them in. install wasn't too bad just a few trial and error stuff, I've never installed/ uninstalled any exhaust system before but it went pretty smooth. until I came to combining the left muffler to the head pipe, it'll only go so far and won't align the muffler with the bracket holes that it mounts to, it needs to come in about an inch more. i've tried pushing it in even more bit it not budging so I then tried filing the head pipe in hopes that maybe it'll thin some of the chrome layer and it'll slide in further but still no. so now I'm thinking as a last*resort*i'm gonna have to cut a piece off a the head pipe in order to slide it in the distance I need, but before I do that i'd like to ask you guys for any info or tips you have to help me out. they are also the 33in slash cut mufflers and would doing this noticeably shorten the length? any info would be appreciated. thanks.
Old Oct 13, 2014 | 12:38 AM
mike hawk's Avatar
mike hawk
I'll tell you this much...
The next time I install slipons, the whole header pipe comes right off...
Old Oct 13, 2014 | 01:01 AM
hockey8787's Avatar
hockey8787
If you have to cut anything then you do not have something right or the wrong product, I would call Samson
Old Oct 13, 2014 | 01:12 AM
Dake's Avatar
Dake
Here is a step by step with pictures. I got mine second hand so this was real helpful without the instructions. Witch are on the site I found out. But I found this more useful.
http://www.hotbikeweb.com/fishtail-t...ails/?image=12
Old Oct 13, 2014 | 11:57 AM
Samson_tech's Avatar
Samson_tech
Former Sponsor
Hi Mayo92,
I'm pretty sure it is you that I have been talking to via email to help you get that rear pipe and muffler installed correctly.
Whatever you do, don't cut the rear pipe. Use some type of penetrating oil on that rear muffler inlet where it is notched and it should allow it to slide in to the position you need it to. If by chance you tightened the barrel clamp down and the notches are extremely tight, I would remove the rear pipe from the Upipe and slide the muffler inlet over the head pipe and gently wiggle it to loosen up the notched portion of the muffler inlet. This will give you the room you need to slide the muffler easily over the rear head pipe.
If you have gotten this far you're doing a great job especially considering this is your first time uninstalling or installing an exhaust system on your bike. Also this is the most difficult installations out of all the systems I have installed which is pretty much everything we manufacture.
Sometimes it's better to take a step back and take a break for a minute and then continue.
You're almost there and if you need any more help just send as many emails as you would like until you complete the installation. You can send pictures as well if you need to.
Thank you,
Brian
Old Oct 13, 2014 | 12:13 PM
shore's Avatar
shore
Get the head pipes lined and tightened, then slide that muffler on and and give it some pressure up and down and then left and right. each time you do this it will open the inlet up a bit. It's harder than you think but a little bit will go along way. You can also take a 2x4 and a hammer to the end cap and gently tap it further on.
100% no need to be cutting anything.
Old Oct 13, 2014 | 01:40 PM
Kenney's Avatar
Kenney
Careful with the hammer. First check the muffler for any “Burrs” that may be inside and causing the problem. Also don’t forget what the header pipe is connected to before you apply too much pressure or “Wiggle” to it. If your still are having trouble take the muffler to a muffler shop and have them open up the pipe (just a little), should be free if you talk nice.
Rauzer
May 4, 2019 03:34 AM
96roadking
EVO
20
Jan 10, 2011 10:19 AM
davlyo
Nov 9, 2009 09:31 PM
t150vej
EVO
14
Apr 22, 2009 07:02 PM
ibridin
Exhaust System Topics
Mar 10, 2007 12:04 AM
