EVO Engine Problem
Old Oct 18, 2014 | 05:24 PM
hdbob2006's Avatar
hdbob2006
If you dropped the carb bowl and cleaned out gunk,you were half done. Any gunk that causes it to starve for gas will be before the needle and seat[fuel intake valve.] Also,replace the rubber line from tank to carb,if you haven't already.
Old Oct 18, 2014 | 09:20 PM
vaxt's Avatar
vaxt
It sounds electrical. Check all the following that your bike has. Kill switch, sidestand (jiffy) cutout, ignition switch.
You could probably just make a jumper to temporarily bypass any kill switches. Definitely start here before you spend any more money.
Old Oct 19, 2014 | 04:02 AM
Big Trev's Avatar
Big Trev
WELL.................That seems to of covered just about every possibility, of what the problem might be
Old Oct 20, 2014 | 08:39 AM
rphillips's Avatar
rphillips
It looks like I had a cam position sensor going bad. The potting for the wires was melting and when you pushed on the sensor with the engine running it stalled. Thanks to all of you for your posts.
Old Oct 20, 2014 | 08:47 AM
heybaylor's Avatar
heybaylor
thank you for the feedback on the problem .
Some folks never do .
Old Oct 20, 2014 | 10:19 AM
hoethree's Avatar
hoethree
I was going to suggest you have the voltage regulator checked. When they get hot they tend to cause similar problems. Glad you found the culprit. I would still check out the regulator.
Old Oct 20, 2014 | 11:17 AM
im's Avatar
im
Use still have crap in the tank..Might be larger piece of tank liner that is blocking fuel flow.
Then after you may wish to install easy to see fuel filter past the shut-off valve.
JDixon
Apr 30, 2017 02:24 PM
HolyHandGrenade
EVO
Aug 5, 2014 06:20 AM
bluharley
EVO
34
Nov 29, 2012 08:43 PM
MidnitEvil
Feb 20, 2011 12:51 AM
Deuce55
May 4, 2010 04:30 PM
