Backfiring
Old Oct 24, 2014 | 06:24 AM
see22ds's Avatar
see22ds
Default Backfiring
I have a 2001 Electra glide (carbed), it has started to backfire when I downshift and start to slow down. Is this what is considered decal popping? Also I have noticed the exhaust pipe changing color at the point where the slip on meets the header pipe...a brown/blue color.
What could be the cause?
Old Oct 24, 2014 | 08:40 AM
Scrambler900's Avatar
Scrambler900
When was the last time the carb was rebuilt or gone thru?
Old Oct 24, 2014 | 11:47 AM
nevil's Avatar
nevil
Backfiring can happen if you have a leak at the intake or exhaust. It's usually on the intake side, but can be the exhaust. Where you see discoloration may mean you have a leak at that joint.
As Scrambler said, it might be a tuning issue with the carb.
Old Oct 24, 2014 | 12:34 PM
Uncle G.'s Avatar
Uncle G.
Have you made any other changes lately that would affect the mixture? Carburetors don't change their own jets. If you've made no other changes (new pipes, air cleaner, etc.), I'd suspect a manifold leak.
If your idle mixture is borderline lean to begin with, the onset of colder weather can aggravate deceleration popping. You might try going up one size on the slow jet and see if it helps.
Old Oct 24, 2014 | 12:44 PM
oct1949's Avatar
oct1949
Only time I had decell Backfire was when I had a muffler leaking and sucking air at the muff to header connection... redid the muffs to get a good seal and back firing gone..
Decell popping is not the same as Decell Backfiring...
Old Oct 24, 2014 | 12:52 PM
Superrust's Avatar
Superrust
Does sound like something has changed. I believe the browning to the pipe is being caused by additional heat. Maybe the carb isn't getting the fuel it needs so it's lean, causing more heat.
To clear the discoloration try this stuff. It's what I've used and had great results.
Amazon.com: Blue-Job Chrome Polish Kit: Automotive Amazon.com: Blue-Job Chrome Polish Kit: Automotive
Old Oct 24, 2014 | 01:08 PM
RHPAW's Avatar
RHPAW
Assuming it's a stock CV carb, try a 180 main jet.
Old Oct 24, 2014 | 03:05 PM
see22ds's Avatar
see22ds
Thanks guys. As far as I know everything is stock on the bike. I just got it this summer and haven't had any issues with backfiring until the last couple weeks. I check out the connection/seal at intake and exhaist first.
imjwag
EVO
17
Oct 31, 2014 08:53 PM
sj032885
Ironhead
Apr 3, 2014 09:41 AM
akmorris81
EVO
Feb 16, 2012 08:55 PM
lagunatic
Ironhead
Nov 10, 2009 12:13 PM
jackofhearts
Mar 1, 2008 05:24 PM
