Bug and Tar Remover
Old Jun 7, 2015 | 04:01 PM
6 gun's Avatar
6 gun
Default Bug and Tar Remover
Does any one know of a safe bug and tar remover,
that wont hurt my paint if i accidentally get a
little on my front finder?
Old Jun 7, 2015 | 04:15 PM
enodrano's Avatar
enodrano
Try Goo Gone for automobiles. It's safe for use on paint:
http://googone.com/Products/Automoti...Gel,-24oz.aspx
Also I have had luck cleaning of bugs using Scotch-Brite Non-Scratch scouring pads on non-painted surfaces. Although I have used them on my powder-coated black handlebars without scratching them.
http://www.scotch-brite.com/wps/port...4631761&rt=rud
If you can't find Scotch-Brite brand pads just look for off brand ones that are for non-stick cookware.
Old Jun 7, 2015 | 04:21 PM
phillyrube's Avatar
phillyrube
For the bugs, just cover them with a wet towel, leave it for 10 minutes, and they wipe right off.
Old Jun 7, 2015 | 04:30 PM
Tampa Fatboy's Avatar
Tampa Fatboy
After you’ve removed the bugs, tar, and sap, wipe it clean, then protect the vehicle with a quality wax or paint sealant.
Old Jun 7, 2015 | 04:31 PM
Uncle Larry's Avatar
Uncle Larry
Just an opinion ... If the OP doesn't know or trust a product recommended for doing the job ( Bug and Tar Remover ), why would anyone suggest a product that will ( more than likely ) be likely to cause damage ... There's no way I'd use any sort of "scouring device" on a painted surface that I wasn't prepared to repaint ... I've refinishing/repainted vehicles for years and I'd NEVER use a scotchbrite or any other type of scouring pad on a finished paint surface ... even if the manufacturer recommended it ... Do as "Philly" suggested and use a cloth with warm water if the bugs are very stubborn
Old Jun 7, 2015 | 05:15 PM
6 gun's Avatar
6 gun
Thanks guys I was thinking about places like the head light housing, and handlebars, and the crash bars, and things like that, but I love the idea of hot water and a towel for the front of the gas tank and front finder. So thank you, to all of you.
Old Jun 7, 2015 | 05:38 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 with the wet towel and use a little WD-40 for the tar and road film.
Old Jun 7, 2015 | 05:40 PM
zeke383's Avatar
zeke383
I hate cleaning my Street Glide, it's black and shows everything.bugs are a pain in the butt. I've tried removers and different methods.
This last cleaning, I found the absolute best way possible to remove bugs. I went to Advance Auto looking for another remover, instead I spent $1.99 on a "bug remover" sponge. It is a spong wrapped in a perforated cover. I went home, filled a bucket of plain hot tap water (my tap water is pretty hot btw). I soaked the sponge and wrang it out well then lightly wiped the bugs off...it was that easy. As I slowly wiped I could see water vapor form in front of the sponge as I moved along. I rinsed and repeated, over paint AND chrome. Then I lightly wiped everything down with a terry cloth, then some detail spray and a clean terry cloth. I was impressed, super super easy. I would recommend this method.
EDIT: this method also doesn't remove wax, water was still beading, thus the quick detail spray
Old Jun 7, 2015 | 05:55 PM
Tedjay's Avatar
Tedjay
I use a product called "Bugslide" to remove bugs.
Old Jun 7, 2015 | 05:57 PM
digger58's Avatar
digger58
For bugs 50/50 hydrogen peroxide and water, spray it on and they melt right off.
Been using that for years and no ill effects on paint or Chrome.
Tar, I still struggle with that
