I try to use both brakes as much as possible. At a stop I keep the bike in gear and clutch in, both feet down simultaneously in case one hits a rock, sand or slick oil spot. I stay off the front in low speed parking lot turns.
I use both brakes to stop. The only time I use the rear brake only is at parking lot speeds. At parking lot speeds, if you use the front brake with the handlebar turned, there is a good chance the bike will go down. That likelihood increases as the speed decreases.
At the motorcycle training course that I took, the instructor told us that we should only put our left foot down at a stop. The right foot should be on the brake, bike in gear with the clutch pulled in. He explained that this puts you in the best position to take evasive action as quickly as possible. I was used to putting both feet down and it's been hard to break that habit. Has anybody else been taught this?
Both brakes, if course, but unless I know its going to be long light, I only put my left foot down, and keep my foot on the brake. Am I the only one who does this? I'm 6' 3" on a Dyna, so I can stand on both feet and not even touch my bike. Keeping it up with one foot is no problem.
I come to a stop and left foot down only as well. Right foot up, clutch in, 1st gear. This is what they taught us to do at the MSV class. There are exceptions, if I know I'm not going anywhere for a while and there's already traffic stopped behind me. Sometimes you gotta give that clutch hand a break. I'm only 5'5 though.. I barely flatfoot.
I use more rear than front after i downshift to a slow speed. At higher speeds i use front to get slowed down faster if needed. When i come to a stop i usually put both feet down just out of habit.
As your speed decreases, the more you turn the handlebars to steer instead of leaning the bike. If you lock the front wheel with the bars turned too far, you WILL go down, and fast!
Even though I learned on dirt bikes, I always use both brakes when stopping, modulating pressure front to rear as conditions warrant.
Both brakes together in normal riding - but heavy front brake bias. Probably 70%+ front
Back brake only at parking lot speeds - plus friction zone on the clutch.
I stop and start with my left foot down and right foot on the back brake.
Motor officers only put one foot down..the one away from the oil slick in the middle of the lane. I Always stop in first gear with clutch in. If stopped on a hill you might need to catch uwanted movement with the front brake.
