Shouldn't use any brake in a turn. Lean the bike more. The act of turning causes friction and slows the bike down. If you must brake, to stop for fallen tree or rock, counter your weight on the bike to maneuver it into an upright position first and then brake.
Apply rear brake and front; smoothly increase pressure on the front while letting off the rear. Then slowly increase pressure back on the rear to decrease your stopping distance.
That's a good point on the left leg down only. I need to try that on the way home tonight.
What's interesting is that when I took the MSF course, they did not mention rear brake only for low speed stuff. I thankfully read about that online before I took the course. Might explain why people in the class were a little wobbly!
It depends on the bike and road conditions for me. In wet conditions I ease on the breaks with more of a 50/50 blend on any bike. In good all around conditions, with the Harley I'm using about 70/30, on my sport bike it's typically 100% front.
It's obvious from the first few pages that everyone seems to have a different method. I just read this article today on trail breaking, it's a good read and something that should be practiced.
I should have added in my post, left foot down, right foot on brake, clutch in, first gear. Scanning, front and rear, until I'm sure the car behind me has stopped, and is not trying to time the light and run up my butt. Since I have my brakes set to flash 3 times then solid, sometimes I get off and then back on the brake as a car pulls up behind me.
The other thing I do, although not specifically taught, unless I am the first car at a light, I put the bike at a slight angle compared to the car in front of me. I'm basically pre-aiming my bike for my escape route, which would be next to the car in front of me, in the event the texter behind me is about to make me a hood ornament. Its subtle, I'm not all cocked, but if I need to jam on it, I can go fast, since I don't have to turn much or at all. I never get too close to the car in front of me.
This also makes starting from a stop easier, since my bike is apparently much faster than the cars in front of me, and I don't have to ride the clutch as much to start slow.
If you were taught to brake that way at your Basic Rider Course, you had a rogue RiderCoach. Students who are taught basic braking skills are taught to use both front and rear brake simultaneously, with progressive squeeze coached for front brake (and rear if needed). Period.
You are correct. For basic riding skills, learning is progressive. The first opportunity for slow speed riding is in a straight line, i.e. the slow ride down the middle. It is very early on in the course (exercise 4). Generally it's difficult enough for them to use friction zone straight line riding without adding an additional thing for them to focus on. Then there are the 90 degree turns, the offset weaves, and finally on day 2, the U-turn box.
Rear brake application can be helpful for slow speed maneuvers. But so can getting your head and eyes up, friction zone and throttle control. There's little time and a lot of information to impart in the BRC. Many students get saturated fairly quickly learning a new skill and there is such a thing as TMI.
I use front breaks most of the time apply bank breaks with the front to make a sudden stop.
My safety class tought me (non abs) that you apply both breaks for a emergency stop if your front break locks release them then re apply. If the back breaks lock keep it locked. If you unlock the results will be worse than if you keep it locked and happen to lay it down.
Now let's hear everyone's Internet opinions on that haha
