Handlebar question
Old Apr 9, 2016 | 03:12 PM
dyna2008's Avatar
dyna2008
Default Handlebar question
I like the bars on my heritage only i wish they were just a bit taller. Would you stick with the stock bars and just add risers? Or just go with mini apes and risers? I was thinking i would also like to cleanup the bars by running the wires through the bars.
I tried rolling the bars forward but that didnt quite give me the height i wanted for comfort.
Thanks in advance for any input.
What would you guys do?
Old Apr 9, 2016 | 03:51 PM
Rick58's Avatar
Rick58
I would go with taller risers myself. Simple and inexpensive, plus I like the stock bars on my Heritage. I actually need to bring mine up and back a bit and I'm researching what I can go with without changing out wires and brake lines.
Old Apr 9, 2016 | 03:57 PM
Tommy C's Avatar
Tommy C
3 inch pullback risers oughta work for you guys.
Old Apr 9, 2016 | 04:09 PM
Rick58's Avatar
Rick58
Thanks. I actually have some 4" pull backs that I bought but I haven't gotten around to installing them yet. They're not as thick around as the stock risers and I'm not sure how they're going to look. I'd really love to be able to put the riser on that come stock on the Softail Deluxe without having to extend any cables and such.
Old Apr 9, 2016 | 07:36 PM
stal94gt's Avatar
stal94gt
A good fit handle bar is worth a lot when it comes to handle bars. Even adding risers may require cable and wire extensions if they are too tall. Also I would upgrade the riser bushings when going up in height. I think adding taller pull back risers with mini apes is a bandaid fix and most end up buying a set of bars that have the correct rise, pull back, and width
Old Apr 10, 2016 | 09:06 AM
weezer_nd's Avatar
weezer_nd
When I had my 2010 heritage, the stock risers from a deluxe was the route I went with. Didn't need to do anything to the cables.
Old Apr 10, 2016 | 10:02 AM
nevada72's Avatar
nevada72
^That^
If you have enough cable slack, keep it simple.
RANGER73
Nov 12, 2018 12:00 PM
Kyfatboy05
Jul 18, 2013 06:15 AM
gnstalodz
Nov 9, 2012 01:29 AM
bikersully
Apr 15, 2010 03:29 PM
Sagexpman
Mar 21, 2010 10:10 AM
