Common Core frames: What is know about them?
Old Aug 29, 2016 | 10:22 AM
ebeattie's Avatar
ebeattie
Default Common Core frames: What is know about them?
The Common Core Frame seems like its going to be the next big thing to change at Harley-Davidson. Question is, what is going to be common about them?
Rumors surrounding the Core frame seem to indicate that the Touring bikes and Dyna Glides will be sharing this frame. If so, I hope that its a win win for both the Dyna and Touring line and not a cheapening of the frame for manufacturing cost reduction.
So, what do we know so far about the Common Core frame?
Old Aug 29, 2016 | 10:31 AM
MiniWolf's Avatar
MiniWolf
I haven't heard a whole lot about it but I think the likely underlying motivation is just cost-savings. That doesn't mean it has to be a cheapening of the frame in terms of overall quality, however. As long as it doesn't hinder performance or utility and is a sound design, it makes sense form a business standpoint to have a common part used across platforms.
Old Aug 29, 2016 | 10:32 AM
skid_pimp's Avatar
skid_pimp
To me, it sounds like platform sharing. The same thing auto manufacturers have been doing for a long time. It will certainly reduce engineering costs for the motor company, as well as reduced production costs. And I assume it would be mostly unnoticed by the consumer ad the Dyna and touring frames are already fairly similar.
Old Aug 29, 2016 | 11:34 AM
jakedaniel's Avatar
jakedaniel
It's really a blast from the past. Back in the old 4 speed days before the FLT showed up in 1980 all the big twin bikes were built off the same frame. Dyna and Touring sharing the same frame just like FLH and FX bikes shared the same frames back in the 70's. I'm sure it saves them money because they'll be able to make twice as many of one type of frame instead of having to have to manufacture two seperate types.
Old Aug 29, 2016 | 11:38 AM
randyp's Avatar
randyp
Can they come up with something that is lighter and stiffer than the the current dyna frame, and still work with the touring line? I hope so.
FXR frames were hand-welded. FXD frames were automated and the automation at the time couldn't handle making FXR frames, but since it was automated it was cheaper to make. I think automation has improved greatly since 1990s.
Then again, the current touring frame is really pretty good. Maybe they're just going to adapt that to the dyna line.
Old Aug 29, 2016 | 11:58 AM
Crashone's Avatar
Crashone
If it has "common core" in the name nothing you do will add up but then anything you do to it will work on it.
Old Aug 29, 2016 | 12:00 PM
ebeattie's Avatar
ebeattie
No matter what happens though, I hope the Dyna remains just over 650 lbs. Even lighter and stronger would be preferable. Have the rear swingarm mounted to the frame and retain the rubber mount Milwaukee 8 with only 50% vibration reduction.
At least, thats what id like to see.
Old Aug 29, 2016 | 12:04 PM
ebeattie's Avatar
ebeattie
Haha, ok I snorted a bit when I laughed
Old Aug 29, 2016 | 02:34 PM
vizcarmb's Avatar
vizcarmb
Does 1 + 1 still equal 2??
Old Aug 29, 2016 | 02:53 PM
mglax13's Avatar
mglax13
