brakes pulsating when almost at stop
Old Oct 1, 2016 | 02:17 PM
rodney123456's Avatar
rodney123456
Default brakes pulsating when almost at stop
Changed brake pads out checked to see if rotor was warped rotor wasnt warped
bled brakes still kinda pulsating at real low speeds almost like i have abs locked up but i dont have abs on 2013 street glide. What else beside rebuild caliper ? Thanks for any info
Old Oct 1, 2016 | 03:10 PM
_Gir_'s Avatar
_Gir_
How many miles on the rotors?
Old Oct 1, 2016 | 03:16 PM
Red's Avatar
Red
What was the runout on the rotors?
Old Oct 1, 2016 | 03:27 PM
watoad's Avatar
watoad
Is it possibly because your Floating Rotors are not floating any more? I've noticed pulsating and have an open question about how I should service the rivets to free them up again on my stock FXDF floating disks. If they can't float they're going to pulse while they're stuck is my guess.
Old Oct 1, 2016 | 05:14 PM
14GuineaPig's Avatar
14GuineaPig
It does sound like a warped rotor(s). HD was replacing them if the were out .008". I had a 2009 FLHTCUI that had 7 sets of rotors up front in 135,000 miles. I don't brake hard and no one could ever figure out why. I hope you get it figured out.
Old Oct 1, 2016 | 06:11 PM
ROCKOUT Rocker Products
Sponsor
The brakes on my '15 Limited Low do that... I can feel it through the rear brake pedal. I took it to the dealer & told them it shuddered so bad it shook the windshield.
They tightened the windshield.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Oct 1, 2016 | 06:20 PM
martinj's Avatar
martinj
Old Oct 1, 2016 | 07:35 PM
rodney123456
i just stuck a piece of wire on the shocks and run it over to the rotor pretty close and couldnt see the rotor moving in and out when i turned the wheel
Old Oct 1, 2016 | 08:04 PM
Longridertx's Avatar
Longridertx
Check it with a dial indicator. Doubt you will see 8-10 thousandths runout using a wire. Sounds like warped rotors.
Old Oct 1, 2016 | 08:08 PM
rodney123456
ok thanks probably just bring it in to the dealer should be covered under the extended warranty
