How much gas is left when on empty?
Old Oct 3, 2016 | 12:30 PM
  #41
japer1372's Avatar
japer1372
My Softail Custom counts down to about 10 miles, and then says "Lo" on the digital readout and the low fuel light comes on.
If I stop within a few miles of that, it will take about 3.75 gallons on a 5 gallon tank.
The actual needle gauge is way off. If will show me at virtually empty when there is still 75 or 80 miles left on the digital gauge.
Once we got caught between gas stations and I was sweating bullets. When we finally filled up it took about 4.85 gallons. I'm not letting that happen again. There is NO fun in riding a bike when you're waiting for it to die at any moment...lol.
Old Oct 3, 2016 | 12:40 PM
  #42
ElectraJim's Avatar
ElectraJim
If I trusted the gas gauge on my '07 EG, I'd be filling up every time I had half a tank. The idiot light(low fuel) comes on when the gauge reads half a tank left. I'm still trying to find out when I should actually be worried about filling up. I rode for 225 miles and figured, it's time to fill up. I put 5 gallons in(tank holds 6). I may have had another 40-45 miles left on the tank? Not sure...
I'll figure it out one of these days.
Old Oct 3, 2016 | 12:50 PM
  #43
MNPGRider's Avatar
MNPGRider
I discovered years ago on my '06 Ultra's gas gauge....When it's full, the needle goes way past the F mark. When it's empty, it goes way below the E mark by an equal distance. I once put in 4.95 gallons into an "empty" five gallon tank.
Yes, I was sweating the last few miles....
Old Oct 3, 2016 | 02:12 PM
  #44
Mid-Night-Rider's Avatar
Mid-Night-Rider
Originally Posted by tlminh
I ride a '15 wide glide. My fuel gauge was on the E, and the speedo dial showed low fuel. I was worried I would run out of gas, but luckily made it to the gas station.
I filled the tank up, but only 3.2 gallons (which took me 105 miles) was filled up. The manual say it holds 4.7 gallons
I had 1.5 gallons left in the tank?
Is the fuel Guage that far off?
105 miles on 3.2 gallons? How are you getting such bad gas millage on a brand new bike? Don't try to push out 200 miles out of a 4.7g tank like a lot of people here do (I am one of them), you'll never make it.
On a side note, I've always wondered how close the advertised capacity is to actual. Do they take into account the huge fuel pump assembly inside the tank?
Old Oct 3, 2016 | 05:25 PM
  #45
hdbob2006's Avatar
hdbob2006
There's so much variation on the Harley gauges,no-one can tell you how much gas is left when YOUR gauge says empty. I know it's a complicated procedure,but you will have to see how much you can put in the tank when it shows 'empty',and subtract that from the advertised capacity of your tank. Sheesh.
Old Oct 3, 2016 | 06:35 PM
  #46
Cobra1's Avatar
Cobra1
Damn, you know how to kill a thread. Lol
Old Oct 4, 2016 | 09:16 AM
  #47
PPBART's Avatar
PPBART
Some years ago I bought a '05 Deluxe. It was a carbuerated model with fuel reserve. I decided to see how far it would go on a tank before run-out, figuring that when it died I would just switch over to reserve and ride to the nearest gas station. When the low-fuel light came on I made sure to stay within close proximity to a station. Sure enough, the engine suddenly quit. I reached down and flipped the petcock to reserve. Nothing happened! It turned out that the previous owner had apparently never used the reserve, and there was some blockage in the petcock. After replacing the petcock, I made sure to periodically set it on reserve and run a few miles!
Old Oct 4, 2016 | 10:28 AM
  #48
rocknrick's Avatar
rocknrick
No gauge or warning light. When the scoot sputters, I just set it on reserve and (when in town) hit the next non-ethanol gas station... Normally takes about 2.8 to 3 gals. 5 gal tank and its supposed to be about 4 gals before reserve, but it is what it is. At least I can comfortably stretch it when I on the road.
Old Oct 4, 2016 | 10:35 AM
  #49
oct1949's Avatar
oct1949
From what most say in here (I must have gotten a weird one).. By that I mean my Gas Gauge has worked PERFECTLY since I got it new in 07 and now with 53K...
Every time my Reserve Light comes on and I stop at the next station, it ALWAYS take between .9 and 1.1 gals to fill up..
Old Oct 4, 2016 | 11:08 AM
  #50
rocknrick's Avatar
rocknrick
LMFAO. Spewed coffee.
