Counter-steering
You will soon find that you can swerve the yellow lines EASILY at 60 mph. That means you will be able to dodge pot holes and other road hazards at road speed. This can and will save your life.
Remember to look where you want to go. Don't look at what you want to avoid. Sight fixation will lead you right into what you are trying to miss.
Anyone here not know what I'm talking about? That's because you never took a BASIC MSF course.
As I challenged, Links, proof, etc. How can you press up at 18 degrees when your are already sitting up above your handlebars?
Put down the meth pipe. Sober up. Check into rehab.
Your head up your *** would more closely match the angle you are describing.
Answer this for the masses. How can you "press up at 18 degrees," when you are already sitting up above your handlebars?
Millions of bikers world wide are anxiously awaiting your enlightening answer.
Park your bike and turn the wheel so you can lock the neck. When you sit on it and straighten the bars, is the right grip high or lower than when it was locked?
Even with the obvious description of ape hangers, the rest of your post makes no sense at all. Your handlebars are NEVER at a lock position when you enter a curve and use countersteering.
And,if they are even with your shoulders, how to you "push up at an 18 degree angle?" I ask again, are you laying down on the tank? How else do you pushe up?
I'm done with this ridiculous thread. I'll leave it up to the masses to reply to your idiotic posts.
Even with the obvious description of ape hangers. the rest of your post makes no sense at all. Your handlebars are not at a lock position when you enter a curve and use countersteering.
I'm done with this ridiculous thread. I'll leave it up to the masses to reply to your posts.
