Counter-steering
Old Oct 11, 2016 | 03:51 PM
  #51
MNPGRider's Avatar
MNPGRider
Originally Posted by ronaldrwl
OK, this is giving me a headache. I started riding 49 years ago without knowing about this. Would you say push left to turn left is equivalent to leaning left? Because that's how I always thought about it.
With all due respect to an honest question (and disregard to the idiots),
Yes, that is what happens with countersteering. All of us have done it without realizing it from the moment we rode a bicycle.
Press left, lean left, go left. Press right, lean right, go right.
That's all you need to know.
Now, let's visualize this. If you are sitting on a bicycle, straight up and down, and turn the handle bars fully to the right (by pressing left on the handlegbars.) If you released the bars, which way would the bicycle lean?
Conversely, If you are sitting on a bicycle, straight up and down, and turn the handle bars fully to the left (by pressing right on the handlegbars). If you released the bars, which way would the bicycle lean?
Countersteering is only reinforcing what we already do intuitively.
Old Oct 11, 2016 | 04:06 PM
  #52
MikerR1's Avatar
MikerR1
First, let me say that you and everyone else have offered good explanations on this.
I recently bought a new bike after not having ridden for a few years. The bike is heavier and has a lower center of gravity than my previous bikes.
The problem I have been noticing is that when I am on the highway and going around a somewhat gently curve, I am having to slow the bike down in order to lean it. But on the highway I do not want to slow down while going through these gentle curves. On my old bike, which was lighter and had a higher center of gravity, I could push down on the bars (push left go left, push right go right). That was not working for my new bike. I was actually doing the countersteering incorrectly but getting away with it.
But now I am thinking, and I will practice this soon, that if I push forward and not down, I will be able to start the lean without having to slow down, which is what I want to do while on the highway.
Also, just as side note, I was also refreshing my knowledge about wobbles today and I realize ( hopefully correctly) that there is a link between wobbles and countersteering. When we push left to go left we are shifting the center of gravity to the left that is why we fall or lean left when we do it. I think that what we are doing when we countersteer is we are initiating a controlled wobble. Of course we are not intending to wobble, we are just intending to shift the center of gravity. In a wobble, the center of gravity is constantly oscillating left and right. I posted another video in another thread that shows us ways to get out of the wobble by shifting our weight on the bike.
Old Oct 11, 2016 | 04:19 PM
  #53
TexasMotorcycleRider's Avatar
Originally Posted by _Gir_
Counter steering is simply making the bike lean in the direction you want to turn. Bikes don't steer, they lean. The more you push the further you lean and the more aggressively you'll turn. If you are satisfied with the rate of turn then you simply hold the bars steady at where they're currently pushed to.
Generally, countersteer is for speeds over .. 15-25ish mph. (each bike is a little different, you'll learn naturally where that transition occurs) If you're slower than that you'll want to turn the wheel in the direction you want to go.
The front wheel actually does steer. If you look closely when you are in a "lean" you will see your tire angled in the direction of your turn a few degrees. So, just lean will not get you around a corner. If you counterbalance the lean and straighten the handlebars to 0degrees the bike will go straight even when it's at a 45degree angle. Stunt riders perform this trick regularly.
Old Oct 11, 2016 | 06:33 PM
  #54
NORTY FLATZ's Avatar
NORTY FLATZ
Wow!
There's some good info in this thread, and some dubious information.
As I teach in my classes, "push left, go left, push right, go right" is really all the students need to know. Sure, we can go into a scientific conversation with frame geometry/tire contact patch movement/suspension travel changes, but the fact remains, "push left, go left, push right, go right."
For the poster that now rides a "heavier" bike, just push forward and the pounds will melt away.
Old Oct 11, 2016 | 06:56 PM
  #55
Bone Doc's Avatar
Bone Doc
I made corn in the microwave tonight.
Old Oct 11, 2016 | 07:15 PM
  #56
MikerR1's Avatar
MikerR1
Originally Posted by NORTY FLATZ
Wow!
Make sure when you teach in your classes that your students understand what you mean when you say "push left go left, push right go right". Make sure they understand that you mean push forward, not push down. You cannot just say "push left go left push right go right" and leave it to the students to figure out what direction in which to "push" the handlebar. I am positive that some of your students will think you mean to push DOWN, when, in fact, you mean to push FORWARD!
Old Oct 11, 2016 | 07:20 PM
  #57
Dynamick's Avatar
Dynamick
Pro tip - hollow out the used cobs and slip 'em over your grips for extra traction. You may need a little peanut butter to hold 'em in place.
Old Oct 11, 2016 | 08:36 PM
  #58
Brewmany's Avatar
Brewmany
Are you not getting that the instructors you are so concerned about have their students ride and practice this stuff? Right after they hear this in the classroom? It's not any more complicated than press right, lean right, go right. Many thousands of students get taught this every year, and it's just that simple.
For God's sake go out and try it for yourself. Or are you being this obtuse on purpose?
Old Oct 11, 2016 | 09:00 PM
  #59
FNGonaRK's Avatar
FNGonaRK
This is a serious forum. How wil, you live with yourself when someone dies because of you **** poor advice. Screw you man. You're a murderer!
Old Oct 11, 2016 | 09:10 PM
  #60
lh4x4's Avatar
lh4x4
Counter steering at highway speeds is not so much as pushing. Very minimal movement. It might be better to say pressure. Put a slight pressure on the opposite bar to the way you are turning. The pressure is to the direction that the bar moves.
