If my passenger isn't perfectly symmetrical up top (if you know what I mean), will I have to adjust my lean angles to compensate?
Yes. If your passenger is sitting upright (ie, not leaning with you and the bike) you will need to lean the bike more, just like if you were keeping your body upright in a curve you would need to lean the bike more than if you leaned with the bike.
Originally Posted by Durango Dave
No, some women do have one breast that may be a little bigger than the other. It is not necessary to compensate when they ride on the back of your cycle.
Edit: Beat me to it. I think I like your answer better, for some twisted reason.....
In addition, it appears I was being a bit too serious (or obtuse) in my reply........
But a passenger has to actively fight against you to be a problem. As the bike leans into a curve a passenger sitting upright will naturally lean as the bike leans. They would have to actually lean to the right during a left turn (or vise versa) to be a problem. It's the same when going strait. A passenger isn't a problem unless they sometimes lean way off to the right and later lean way off to the left.
A passenger does not have to do anything out of the norm when you countersteer.
Please go back to my previous post (#821) and review my quote from the youtube video you so proudly posted. No, wait-- I'll repeat it here for you:
"Your bike has a natural tendency to stay upright, which gets stronger the faster you go. So, the faster you go, the more you need to actively countersteer, even through the turn, to overcome the self righting tendency. At race speeds, racers are actually using a tremendous amount of countersteering force just tokeep their bikes leaned over".
Countersteering can be used two ways, apparently--at least according to this video (which, as you know, I and quite a few others agree with). One is to initiate a turn, the other is to stay in the turn. It says it right here, in the video you linked to, at 3:45:
Just realized... I'm probably on Mikey's ignore list. So much the better....
Your stuff in red is questionable..
You are mixing other characteristics in with what counter steer is.. Self righting is based on tire profile and rake / trail.. Trail is what uprights the bike.. Not sure what you mean by "actively counter-steer" Do you mean more turn on the bars? Or more force? Sounds like you are mixing the gyroscopic forces of the wheels with counter-steer to set up the turn.. They are different.
The last sentence in red really depends on the bike.. For me the most common is that the bike wants to self right which means you need to pull the bars into turn (over-steer?) when the rear tire is bald / squared. The rest of the time you want steering to be neutral while in the corner. That's tire contour / rake / trail..
BTW, The video has an error.. You counter-steer going into the turn and not coming out.. Coming out of the turn you over-steer. You need to turn the bars more to get the tires back under the CG vertically.
It's not my stuff. It came directly out of the video I linked to. The one that Mike linked to in support of his assertions.
I don't think so. Oversteer implies that you gave the bike too much input and it then reacted more than you intended.
the one girl I'm thinking about is really massively unbalanced... heck, I think she leans about 10 to 15 degrees just normally... walking. She's never ridden with me, but I do kinda wonder if it would be fun
"So, the faster you go, the more you need to actively countersteer, even through the turn, to overcome the self righting tendency. At race speeds, racers are actually using a tremendous amount of countersteering force just tokeep their bikes leaned over".
They may have used the words "counter-steering force" to describe it but what they are talking about is the pressure you need to keep on the bars just to maintain the lean. If the lean angle is not changing you are not counter-steering.
The bike wants to counter-steer. It does not like being leaned over. If you remove the pressure, the bike is going to counter-steer itself to a zero lean angle. If you remove the pressure on the bars, the lean angle will change. If you keep the pressure on the bars the lean angle will be stable.
Removing the pressure from the inside bar is equivalent to pushing on the outside bar with twice the force that you are holding on the inside bar.
Stuff
[/COLOR]
Yeah,, It's still questionable.
You call it what you like, terminating the turn ain't counter-steer.. Unless your definition is different.. For me counter-steer means turning the handlebars in the direction opposite the desired direction of travel. Over-steer sounds good, as to pull out of the turn, you need to turn the handle bars tighter into the turn than what is needed for correct line through the turn.
Add:
I've been thinking about what I said and "terminating the turn ain't counter-steer." It could be considered counter-steer.. Define counter steer as simply, "steering the bike in the direction opposite the desired direction of travel" In that case you are counter steering at the end of the turn by turning tighter when you want to go straight.
Reason: Add: correction
