Counter-steering
The OP, MikerR1, has simply changed the definition of countersteering to something else, and he's now arguing that everyone is wrong, because everyone except him is using the correct definition of countersteering.
Countersteering is the application of pressure on the handlebars in the opposite direction of the intended turn. That's it. That's all there is, there ain't no more.
You apply more pressure at the beginning of the curve than you apply in the middle of the curve to maintain the radius of the curve. It's still countersteerting, all the way through.
At the end of the curve you can relax or release the pressure and the bike will straighten up, or you can actively reverse the pressure so that the bike will straighten up much more quickly, which is what you would do if you were setting yourself up for an immediate change of direction to a turn the opposite way. That's why bombing through a series of tight S curves is so much fun, it's that transitioning from one direction to the opposite direction with an aggressive change in handlebar pressure.
Doesn't get much more fun than that!
According to your definition countersteering is merely the application of pressure to the bars. That is not the definition.
A few days and posts ago I asked you a question and you never answered it. I asked you why the the definition of counter-steer always has the word "momentary" in it as in the following definition...
The above definition does not say anything about pressure, it says counter-steering not counter-pressure. There is a big difference.
What you are trying to do is to define a new term, counter-pressure.
According to your definition countersteering is merely the application of pressure to the bars. That is not the definition...
The definition of countersteering absolutely does not "always" include the word "momentary".
During the two day, 16 hour motor officer type training that I've taken, twice, I asked the senior Motor Officer Instructor for the entire state this question: "Do you keep countersteering throughout the curve?"
"Yes, absolutely."
Of course, he's wrong and you're right.
I can search the internet and come up with anything I like.
"Yes, absolutely."
By making that not so simple change you make my point. If you apply pressure to the bars but you do not move the bars you are not counter-steering. You are just keeping pressure on the bars to maintain your lean.
You need to read this post by bwoltz. He absolutely nailed counter-steering and he speaks using the terms that I am sure you will understand. https://www.hdforums.com/forum/showthread.php?p=15618214
By making that simple change you make my point. If you apply pressure to the bars but you do not move the bars you are not counter-steering. You are just keeping pressure on the bars to maintain your lean....
Period.
I think you should read this post by bwoltz. He absolutely nailed counter-steering and he speaks using terms that I am sure you will understand. https://www.hdforums.com/forum/showthread.php?p=15618214
When you hold pressure on the bars you are still turning left, but you are turning left with a constant lean angle and arc. If you want to change that arc, you have to push harder on the bars to make the bike fall over and then quickly turn into the direction of the new lean. Then your front wheel will be pointing to(on) a new arc. The only reason you counter-steered was to get the bike to go out of balance so it would fall over some more so that you could turn into that new lean and create a new path. The whole point is to get the front wheel pointing to a new, tighter, path. To maintain that new path you are going to have to keep even more pressure on the bars.
