Counter-steering
Old Oct 24, 2016 | 07:42 AM
  #901
MikerR1's Avatar
MikerR1
Originally Posted by keith_stepp
What is this thread up to now... 80 pages? lol
Dude. You are still wrong.
So, I haven't caught up with all of the posts since my last one to the most recent and I won't. But, I thought I would take a moment and just say that...
Counter-steering is used to maintain lean angle in most situations, not all, but most. It seems to me that you are confused by the word "steering" in the term "counter-steering". Counter-steering does not "steer", it creates lean and leaning steers the bike.
No, I am not confused, I have been saying consistently, that counter-steering is used to change the lean angle.
If you think about what you just said, that counter-steering creates(changes) lean, then it should be obvious to you that you cannot counter-steer continuously or you will lean yourself right into the ground.
The simple fact of the matter is counter-steering has to to momentary. It cannot be anything but momentary. When you are counter-steerig the bike is unstable and out of balance. You have to turn into the lean to re-stabilize the bike.
If you are counter-steering to initiate a turn, the simple fact is, you cannot do it for a long period because if you do you end up on the ground. If you counter steer in the turn the same physics apply, it has to me "momentary", otherwise you lowside.
If you are in a turn and holding pressure on the inside bar to maintain your lean, you can slowly release the pressure to slowly upright the bike. Each time you release pressure, you are "momentarily" counter-steering. If you release the pressure all at once the bike will immediately upright.
The word "momentary" is in the definition of counter-steering because counter-steering cannot be anything other than "momentary". I take that back, you can counter-steer for periods more than "momentary" but you are going to counter-steer yourself right into the ground (lowside or highside) if you do.
When you lean angle is constant you are not counter-steering. You counter-steer to change you lean angle.
Old Oct 24, 2016 | 08:24 AM
  #902
rjg883c's Avatar
rjg883c
So you are saying is that in a fast continuous right turn we don't turn slightly left to prevent high siding or turn right in a left turn for the same reason? Obviously you still haven't gone for a ride and looked at your triple clamp during a fast turn. In this case you don't "You counter-steer to change you lean angle", you counter-steer to prevent a highside. And it is not "monentary". Unless, such as with 'counter steering', you have your own definition of 'momentary'.
Do you really not understand centrifugal force?
Troll.
Old Oct 24, 2016 | 08:35 AM
  #903
rhythm1978's Avatar
rhythm1978
91 pages on a motorcycle forum debating the technicalities of steering a motorcycles. I understand counter steering but have never sat and tried to dissect it. What's the point?
Old Oct 24, 2016 | 08:40 AM
  #904
roussfam's Avatar
roussfam
Conversation starter?
Old Oct 24, 2016 | 08:46 AM
  #905
MikerR1's Avatar
MikerR1
Troll.
As bwoltz pointed out, if you are in a turn, your wheel is going to be pointed to the inside if you are not counter-steering.
I did not mean to imply that you cannot counter-steer to prevent a high side or low side. "Momentary" means for as long as necessary to fix the problem.
Old Oct 24, 2016 | 08:55 AM
  #906
MikerR1's Avatar
MikerR1
Just listen to the first 10 seconds of this video and you will understand why it has gone on for 90 pages.
"Counter steering is an interesting and often misunderstood topic in the motorcycle world..."
Three words in that description have kept this thread going, the word "interesting" and the words "often misunderstood"
  #907
rjg883c's Avatar
rjg883c
As bwoltz pointed out, if you are in a turn your wheel is going to be pointed to the inside if you are not counter-steering.
Apparently neither you nor bwoltz has gone for a ride and looked down at your triple clamp during a high speed turn. During a low speed turn 'your wheel is going to be pointed to the inside because there is no need to counter steer in order to prevent high sides'. Again perhaps you have a different definition of "momentary"
What is your definition? This could all be ended if you simply went for a ride?
Actually I discovered this process back in the '60s, long before hearing the term 'countersteer'.
Old Oct 24, 2016 | 09:03 AM
  #908
MikerR1's Avatar
MikerR1
Apparently neither you nor bwoltz has gone for a ride and looked down at your triple clamp during a high speed turn. During a low speed turn 'your wheel is going to be pointed to the inside because there is no need to counter steer in order to prevent high sides. Again perhaps you have a different definition of "momentary"
I gave you my definition of "Momentary".
I also gave you a whole bunch of pictures of motorcycles in fast turns. Here they are again.
https://www.google.com/search?q=lean...w=1195&bih=807
Why don't you film what you are talking about and post the video. As you say, you cannot tell anything from a still photograph.
The direction this wheel is pointing seems to contradict what you have been saying and support what bwoltz is saying. Frankly, this picture makes sense. I love this picture.
I love this picture too
Old Oct 24, 2016 | 09:05 AM
  #909
Ghost_13's Avatar
Ghost_13
Mental masturbation
Ghost
Old Oct 24, 2016 | 09:07 AM
  #910
rjg883c's Avatar
rjg883c
So you don't really ride? Troll.
