Counter-steering
Old Oct 24, 2016 | 09:07 AM
  #911
Uncle Larry's Avatar
Uncle Larry
This whole thread reminds me of "Riding With Ron" ... :>(
Old Oct 24, 2016 | 09:09 AM
  #912
Jay Guild's Avatar
Jay Guild
Jabba Jabba Jabba Jabba Jabberjaw!
Just to keep the thread going. Not enough going on in the last couple hours.
Old Oct 24, 2016 | 09:11 AM
  #913
rjg883c's Avatar
rjg883c
What is "Riding With Ron"?
Old Oct 24, 2016 | 09:31 AM
  #914
Uncle Larry
Ron was the "Expert" who showed up and knew everything about riding/braking and told everyone we knew nothing and he knew everything ... Like using both brakes was unnecessary and the only brake needed was the rear. He was even better than the Officers who rode the Competitively ... Just ask him. :>(
Old Oct 24, 2016 | 09:56 AM
  #915
Max Headflow's Avatar
Max Headflow
Originally Posted by keith_stepp
Counter-steering is used to maintain lean angle in most situations, not all, but most. It seems to me that you are confused by the word "steering" in the term "counter-steering". Counter-steering does not "steer", it creates lean and leaning steers the bike.
I would disagree on this one.. A common way to make corrections in the corner is to use the throttle. Roll off for more lean. Roll on coming out of the corner. You can do this without changing your handlebar angle.. You can do this without counter-steer..
So far what I'm getting here, the definition of counter steer is nothing more than simply balancing your motorcycle.. Going straight down, the ride is constantly maintaining balance, hence counter-steering.
For me the definition of counter steer is / was which way you had the wheel pointed from center. If the wheel is pointed in the opposite direction of center from the direction of the turn, the rider is counter-steering. With that definition, you only counter steer going into a turn and if the rear wheel is drifting to the point your wheel is no longer turned into the turn (turned out). you are counter steering.
Old Oct 24, 2016 | 10:04 AM
  #916
Max Headflow
Originally Posted by slodsm
I'll just leave this here.
For me this is counter-steer as the wheel is different then the direction of travel from center. In the picture, the rear tire is sliding and the rider is counter-steering to keep his line. He is is likely adjusting the steering (front wheel) to maintain balance but I don't consider that part "counter-steering". It's simply balancing.
Old Oct 24, 2016 | 10:09 AM
  #917
rdam's Avatar
rdam
Open an account, ask some basic question that can be answered with a simple search, and then commence to stir the pot and answer your own question. In fact, I think he started another thread where he asked a question in the title, then answered his own question in post 1.
Maybe it's one of those scams where an established online identity has value to companies trying to sell items on an online forum. Maybe Mike is a retard in a group home. Maybe Mike is dying in a hospital, and living out his last days discussing and debating things he wish he would have done. Perhaps Mike is a bullied adolescent, escaping reality by pretending to be an educated adult on a forum of what he perceives are "real men".
Or maybe a combination of the all the above. Regardless, I love seeing Mike reply, in a serious tone, to blatantly sarcastic comments. It makes me lean (or counter lean) toward teenager, or stunted young adult. Would an actual, normal adult motorcycle rider ask and reply similarly? Didn't we have something similar a few months back.
Personality profiles are fun.
Old Oct 24, 2016 | 10:22 AM
  #918
RHPAW's Avatar
RHPAW
Maybe he should just ride facing backwards. Then, nothing is "counter-steer".
After he goes 50 feet and dies, we can go back to important things, like gas caps and 3-piece patches.
Old Oct 24, 2016 | 10:53 AM
  #919
keith_stepp's Avatar
keith_stepp
I don't disagree. There are a lot of forces at work that influence the angle of the lean, but we were talking only about counter-steering.
Old Oct 24, 2016 | 10:55 AM
  #920
keith_stepp
That is not counter-steering. It is called "turning into the slide".
