Blue loc tite question
Old Apr 20, 2017 | 12:50 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Default Blue loc tite question
I used a dab of blue Loctite on my highway pegs and my seat screw. But when putting the pegs on I had to remove them and re-adjust the position several times. Same with the seat being swapped back and forth when my ol' lady rides with me. My question is do I need to re-apply Loctite each time I remove the bolts or screws or is it once and done?
Old Apr 20, 2017 | 12:52 PM
Halojumper's Avatar
Halojumper
Yes, you need to re apply it each time. You have broken the bond when you removed it.
Old Apr 20, 2017 | 01:01 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Yes you always reapply as mentioned above. A little goes a long way.
Old Apr 20, 2017 | 01:03 PM
penmaker's Avatar
penmaker
Clean the threads and reapply
Old Apr 20, 2017 | 01:19 PM
baka1969's Avatar
baka1969
^^^This^^^
Old Apr 20, 2017 | 01:51 PM
deadhawg's Avatar
deadhawg
When adding something like highway pegs, I put them on without lock tight, take a short ride, make any adjustments needed, then use lock tight.
If I have to move them later, clean the threads and reapply.
Old Apr 20, 2017 | 01:57 PM
Ghost_13's Avatar
Ghost_13
Use only HD Orange loctite
All others are inferior
You read it on the internet - so it must be true
Ghost
Old Apr 20, 2017 | 03:07 PM
adm's Avatar
adm
I wouldn't bother Loctiting the seat bolt. Especially if you are swapping seats often....
Old Apr 20, 2017 | 03:16 PM
Hey Man's Avatar
Hey Man
Ghost
Yeah, keep yer Harley all Harley or some day your sticker won't peck out.
t.
Old Apr 20, 2017 | 07:21 PM
Iron lHorse's Avatar
Iron lHorse
Loctite doesn't dry because it comes in contact with air . So if you still see it on the treads I would just retighten it .
