Rear brake caliper options
Old May 8, 2017 | 07:04 AM
Evoken's Avatar
Evoken
Default Rear brake caliper options
I would like to improve my rear brake performance. I changed the pads to lyndal gold street pads and they are definitely better. However the system is still lacking.
This is for my 98 softail, factory caliper. I will be upgrading to s.s. lines and will rebuild the m.c.
What is everyone's thought on the P.M. calipers? I know they claim they are better, but I can buy new aftermarket factory style for about 250 for new caliper and chrome bracket. The P.M. kit is about 500. Are they really that much better?
I don't like the double price tag, but if they really are that much safer I wouldn't hesitate. My other concern is the need to run P.M. pads. The stock configuration gives me a plethora of pads to choose from and are readily available.
My current caliper is in good shape so a rebuild of that won't get me much if anything. I just don't want to shell out 500 bones for the placebo affect. I.e. they were expensive so have to be better. Anyone running these notice a vast improvement? How available are the pads, special order? Thanks.
Old May 8, 2017 | 07:29 AM
Yamaharley's Avatar
Yamaharley
I would rebuild the master and put on stainless lines with new fluid first. If that isn't enough then a new caliper is a good option and maybe a floating rotor. I have a pm 4 piston on the front and I think it works great and looks good for the money.
Old May 8, 2017 | 09:32 AM
tommyglide's Avatar
tommyglide
The stock rear caliper on my 09 works well, probably an upgrade from your year model, however for the front (single caliper) I tried an expensive name brand 6 piston differential bore caliper which was dissapointing, replaced it with a 4 piston Brembo from QTMI and NOW,,,,, I have brakes.
Sportsterd
May 2, 2021 03:59 AM
spaceblue
Dec 31, 2010 02:25 PM
ottoman007
Apr 3, 2010 07:13 PM
asphalt hog100
May 2, 2008 12:17 AM
heavy.clutch
Ironhead
Aug 14, 2007 12:01 AM
