Drilling Fender?
Old Jun 6, 2007 | 07:28 PM
fatboy4ever's Avatar
fatboy4ever
Default Drilling Fender?
I have an 06 Fatboy with a hell of nick on the front fender (following too close to a gravel truck). I tried to match the custom color from the dealer "dragonfly green", but the paint kit doesn't do it. It looks like I can cover the nick with a front fender tip. I don't like the look of Harley's front tips for the Fatboy, so I went with National Cycle's tips.My concern is drilling into the sheet metal. I didn't give a damn on my metric cruiser when I installed my last "tips", but I don't want to screw up the paint job on this bike. Any suggestions on the best method to drill holes?
Thanks,
Scott
Old Jun 6, 2007 | 07:38 PM
vegashd's Avatar
vegashd
Default RE: Drilling Fender?
Take masking tape and cover the tip of the fender. Mark you hole and drill away. start with a pilot hole and then go larger to the required size.
Old Jun 6, 2007 | 07:51 PM
fatboy4ever
Thanks VegasHd:
Would you suggest priming the holes after I drill or is this an unecessary step??
Thanks
Old Jun 6, 2007 | 07:52 PM
silver1's Avatar
silver1
Exactly what I would reccommend and of course don't drill into the tire. Didn't even have to say that right!
Old Jun 6, 2007 | 07:56 PM
fatboy4ever
Thanks Silver, I was thinking of putting a block of wood between the tire and fender for added assurance and insurance. I was also afraid of bending the sheet metal when I drill. Usually not this **** retentive, but I "shiver" when I approach my bike with a tool in my hand.
Old Jun 6, 2007 | 07:59 PM
silver1's Avatar
silver1
I know what you mean...I wouldn't hesitate one minute to drill your fender but would really study it hard before I did my own.
Old Jun 6, 2007 | 08:15 PM
fj4069's Avatar
fj4069
tape it mark it and then use a springloaded center punch to start a small indentation for the pilot drill bit. then drill to size. with the tape still on prime the hole to get the inside edges of the hole.
Old Jun 6, 2007 | 08:36 PM
whaap's Avatar
whaap
I would paint the hole with any paint I happen to have in my garage cabinet. Whether it's primer or a paint color shouldn't make much difference since all you're doing is a litle rust prevention.
Old Jun 6, 2007 | 08:53 PM
John TN's Avatar
John TN
What they said about the tape and remember on a rounded surface even with a spring punch that bit is going to walk on you.
I'm going to add after tapingput on the fender tip make sure it lines up like you want it to, either tape it in place or have someone hold it anduse the holes in the tip foryour guide, this way you don't end up with holes that are off and have to be redrilled or enlarged.
Old Jun 7, 2007 | 08:35 AM
ci330guy's Avatar
ci330guy
It's also best to drill up to the size you need...1/16" to 1/8" to 3/16" to 1/4"...
