Question About 2017 M8 ECM
Old Jun 28, 2017 | 09:12 AM
rgk's Avatar
rgk
Default Question About 2017 M8 ECM
I have a 2017 Tri Glide. I am going to install a set of V&H Trike DeLuxe slip ons because I like the sound. Will the ECM adapt to the new pipes without installing a tuner/and or Stage 1 intake? Thank you for your responses.
Old Jun 28, 2017 | 09:15 AM
Redoilokie's Avatar
Redoilokie
With just the pipes you should be fine, no need to tune.
Old Jun 28, 2017 | 09:44 AM
RK4ME's Avatar
RK4ME
No tech support at V&H?
Old Jun 28, 2017 | 02:06 PM
RandyL's Avatar
RandyL
I would recumbent a power vision from fuel Moto. the stock HD tune is lean to comply with the eps.
a power vision on a 100% stock bike will improve the performance.
but, no, one is not needed for now.
Old Jun 28, 2017 | 02:20 PM
TKDKurt's Avatar
TKDKurt
The rule of thumb used to be that if all you were doing was putting on slip-ons without opening up the breather, you didn't need to flash the ECM or add a tuner. Interestingly, however, my buddy just got a 2017 RK Special and if you look at the H-D street cannons for that bike (which he did) it says that a tuner is required. I'm not sure why that is now the case, I just call that change to your attention. Those answering from experience with non M8 motors may not be aware of that change.
Old Jun 28, 2017 | 02:30 PM
Buelligan666's Avatar
Buelligan666
But that will give the MOCO grounds to void the warranty. I've read about a couple guys getting denied warranty because the ecm shows that it's had an aftermarket tuner attached. YMMV
garye5007
Mar 10, 2018 12:18 AM
kman21
Apr 23, 2015 08:15 PM
BikeAriz2
Nov 30, 2010 02:29 PM
10ring
Jan 15, 2009 01:31 PM
Garrison1383
Mar 22, 2006 03:34 PM
