Need advice cleaning engine.
Old Sep 5, 2017 | 08:55 PM
C908's Avatar
C908
Default Need advice cleaning engine.
I have 40,000 miles on my Ultra and the engine needs to be cleaned. While I keep my bike very clean I normally leave the engine alone. I have always avoided using a high pressure hose but now I feel that's what I need. My engine has what I would call oil seepage in various places however I do not have any oil drips on the floor. I was wondering what product is used the most for cleaning engines. How many of you just use the high pressure hose at the car wash ? Thanks
Old Sep 5, 2017 | 09:15 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I just use a regular spray hose but I never let it get really dirty. When it dries, I use an "engine brightener". It makes it look like new.
Old Sep 5, 2017 | 09:29 PM
coop creek's Avatar
coop creek
well I do use the local car wash a few times per year. it has a few bays designed for motorcycles with a wheel chock and a lift. The pressure wand is high volume moderate pressure, way more than a garden hose but not like a pressure washer you would use on your deck etc. I use the soap/wash and then high pressure rinse. I do not use the pre-soak/degreaser which I suspect etches the aluminum. I have not had any problems.
Old Sep 5, 2017 | 09:38 PM
QC's Avatar
QC
Some in here like the S100 cleaner. On my blond engine I use full strength Simple Green and a toothbrush.
Old Sep 5, 2017 | 09:59 PM
rhuff's Avatar
rhuff
Use simple green diluted to about 5:1 Let soak about a minute. Rinse off with medium pressure garden hose (just use the old school finger over then hose end). Then, use engine brightener. If it needs more than that, do it again. Or get out the fine tip cleaning tools and get to work.
Old Sep 5, 2017 | 11:26 PM
RK4ME's Avatar
RK4ME
I usually hand wash my bike, engine and all. Coin op car washes do a crappy job.
Old Sep 6, 2017 | 06:21 AM
YeOldeStonecat's Avatar
YeOldeStonecat
For gunky old build up....hit it with some engine degreaser foam. Follow up on stubborn spots with a big spray can of carb cleaner.
Blast off with the water hose
repeat....repeat...do this a few times over a few months and she'll get to where you want. Bike prior to current one was an old Shovelhead I bought in really rough shape, who knows how many miles but both rocker top box gaskets had been seeping badly and dripping down both jugs and cooking on. That engine was a nasty looking mess. The above approach is all I did and she looked darned good after a short while, frequently getting compliments.
Let her dry really well, even run it to warm up and help dry better. Cool down a bit and spray on some engine brightener...like S100 which you can find nearly anywhere, or if you can find Pig Spit...I prefer that better...I find it stays on there longer.
Old Sep 6, 2017 | 06:47 AM
Larry64's Avatar
Larry64
Gunk Foamy Engine Cleaner, a paint brush with duck tape over the metal part, and followed up with engine brightener.
Old Sep 6, 2017 | 08:56 AM
RK_Classic's Avatar
RK_Classic
Yup. S100 (full strength). Spray it on a cold motor let is sit a few minutes then hose off, too my surprise it works very well.
rk classic.
Old Sep 6, 2017 | 09:03 AM
Veekness's Avatar
Veekness
Original Gunk works great for me. NEVER use s pressure washer on your bike! Otherwise you'll be joining many others on this forum crying about the crappy wheel bearings Harley puts on their products!
