Help Please, in Daytona with no brake light?
Old Mar 19, 2018 | 12:49 PM
RHD51's Avatar
RHD51
Default Help Please, in Daytona with no brake light?
Hey guys, I could use some help please.
I am in Daytona and my brake light quit working. I have traced the problem to the rear brake light switch. The problem is I don't have my service manual and don't know the procedure to replace the switch?
When I remove the switch will I loose brake fluid?
Assuming I will loose fluid I would expect to have to bleed the brake and add fluid? Is this correct?
Can anyone give the correct procedure to get this done?
Thanks for any help.
Bike is 07 Heritage (see sig)
Old Mar 19, 2018 | 12:57 PM
TriGeezer's Avatar
TriGeezer
If the brake light still comes on with the hand caliper, why not make sure you use that until you get home, and have better conditions to repair it!
Old Mar 19, 2018 | 01:00 PM
RHD51's Avatar
RHD51
I am going to be in Daytona for another three weeks and need to get it fixed ASAP.
I am not comfortable with having to remember to use the hand brake every time.
Old Mar 19, 2018 | 01:10 PM
Tom84FXST's Avatar
Tom84FXST
Two wires...doesn't matter where they go, so you can't mix them up...lefty loosey , righty tighty...I have replaced them before without bleeding...have the new one ready, and don't waste anytime installing it and you will only loose a couple of drops...worse case rear brake will be a little spongy till you get a chance to bleed...5 minutes in a dealer parking lot.
Old Mar 19, 2018 | 01:11 PM
Cbyway's Avatar
Cbyway
Let not your heart be troubled. Ride that sum beach into the nearest HD dealership. Take the gas cap off, walk in holding the cap in the air and tell the first salesman you need a new bike that will fit this cap.
Old Mar 19, 2018 | 01:23 PM
KCHD1's Avatar
KCHD1
You can afford three weeks in Daytona, but can not afford to take your bike to the dealer so you don't get rear-ended? And you can't remember to use the front brake, you don,t use it every time you stop? I'm CONFUSED !
Old Mar 19, 2018 | 01:26 PM
RHD51's Avatar
RHD51
Thanks Tom, It appeared like an easy fix, just needed a little confirmation.
Old Mar 19, 2018 | 01:30 PM
Cbyway's Avatar
Cbyway
Good luck, I hope you figure it out. I was just trying to set you up with an extra gas cap for the ride home!
Old Mar 19, 2018 | 01:33 PM
WP50's Avatar
WP50
Do what Tom84FXST says and be sure to leave the cap on the reservoir while changing the switch. Done stuff like this a good many times over the years
WP
RHD51's Avatar
RHD51
Actually it will be six weeks in Fl. Four in Daytona and two by Palmetto, on the the West Coast. Not that my financial situation is any of your concern, I am doing it on the cheap, in my travel trailer, on a friend's property.
It's not that I can't afford the dealer repair, I just want to do as much of the wrenching on my bike as possible.
