Discharged battery
Old Mar 21, 2018 | 07:23 AM
Joshus41's Avatar
Joshus41
Default Discharged battery
I have a dead battery how long does it take for a HD tri kle charger to top of a battery The bike is a 2017 ultra I've been riding since 1975 in northern Ohio with everything from a sportster to road king to ultra. And never had a battery take a dump over the winter even with stRying when the temps got to the upper 40 what the hell happened bad bat or what?
Old Mar 21, 2018 | 07:27 AM
Cbyway's Avatar
Cbyway
Obviously it wasn't on a tender? It may charge it enough to start the bike pretty quickly. The bike is under warranty. Call the dealer, they may come get it and for sure will replace the batter.
Old Mar 21, 2018 | 07:29 AM
DresserDude's Avatar
DresserDude
How bored and retarded are you to keep making nonsense posts continually?
Old Mar 21, 2018 | 07:37 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
The security , ECM, speedometer, and other items all have small processors that stay on drawing very small amounts of current.
You really should make sure your connections are tight at battery. Charge it a good 24 hours and keep it on there ever chance you get for a week to hopefully desulfate it. Dragging these small batteries all the way down shortens their lives dramaticly. If it seems weak after a week and you use the bike for more then a hobby where if it does not start and this would be a real problem, I would get a new battery.
My older bike actually draws more then new bike and sees to be OK for about 2 months. Iffy then. Three months is usually a no start plus you are putting all that starting and charging load on your bike.
If driven weekly, all is good but any longer, use a under 1 amp quality maintenance charger.
Don't leave it on all the time. You can let the battery get too worn out and the last start will be when you take it off the charger and a no start when you head home.
Good life is about 4-5 years
Old Mar 21, 2018 | 07:45 AM
Cbyway's Avatar
Cbyway
Geez, man sorry I offended you. I have a fresh pot here, I would gladly pour you a cup if I could. Have a nice day.
Old Mar 21, 2018 | 07:52 AM
Brewmany's Avatar
Brewmany
Parasitic drain from the security system, etc... could drain the battery during a few months of non use. Keep the battery on a tender to keep this from happening. Not a trickle charger, but a battery tender/monitor. I keep my bike hooked up to one all winter, battery stays charged. Not sure this is a warranty issue. Or if the battery even needs to be replaced.
Old Mar 21, 2018 | 07:59 AM
JackStaff's Avatar
JackStaff
"The bike is a 2017 ultra I've been riding since 1975 in northern Ohio..."?
Old Mar 21, 2018 | 08:08 AM
joe.1955's Avatar
joe.1955
Originally Posted by JackStaff
"The bike is a 2017 ultra, I've been riding since 1975 in northern Ohio..."?
I read it the same way at first, punctuation does make a difference.
Old Mar 21, 2018 | 08:23 AM
Veekness's Avatar
Veekness
Before you jump down dresserdude's throat, how about you do what he, dynamick, and others have done? Check out OP'S profile and posts.
After you do, you will realize that he' a troll stirring up crap just to stir up crap. If you feel the need to participate in his nonsense, well...fine.
Old Mar 21, 2018 | 08:27 AM
JackStaff's Avatar
JackStaff
Grammar and punctuation!
"the difference between knowing your **** and knowing you're ****'!
