Fuel tank
Old Jun 14, 2018 | 09:08 AM
TomiT's Avatar
TomiT
Stage IV
Default Fuel tank
I own a 2003 heritage flstci once I've used half tank gas she starts to sputter and drag. It doesnt do that when full only at half tank. Ideas?
Old Jun 14, 2018 | 10:46 AM
JohnSWA's Avatar
JohnSWA
You have a small hole in your fuel line. It's a common problem. The line is inside the tank connected to your fuel pump. Replace it with a submersible fuel safe rubber fuel line and you'll never have this problem again.
Old Jun 14, 2018 | 10:52 AM
dyna rider's Avatar
dyna rider
Default Tank Hoses
Sounds like you need to change the hoses inside the fuel tank. If there is a hole worn in the internal hose from the fuel pump. When the gas level gets below that hole, you will get air in the line and it will cause the sputtering. While you are in there, you can change the fuel filter which can cause the same problem, even with a full tank.
NAPA has better hoses than the stock HD hoses and WS6 FORMULA did a good write up.
https://www.hdforums.com/forum/dyna-...fuel-line.html
Old Jun 14, 2018 | 10:53 AM
Scudda's Avatar
Scudda
If you are going in there you should replace the fuel filter and the line and check valve. You can buy both parts from either HD or Drag Specialties makes them. I used the DS parts in my 05 Fat Boy over the winter
Old Jun 14, 2018 | 10:58 AM
TomiT's Avatar
TomiT
Stage IV
Default Fuel Tank
Thanks for your help!
Colorado Mac's Avatar
Colorado Mac
This. I had this problem once and a new line fixed it.
randazlr
13
Jul 13, 2017 10:36 AM
toxic
Apr 8, 2015 03:27 PM
krzldy1949
Jun 24, 2014 11:45 PM
jaxx1972
Jan 4, 2011 04:46 PM
mulch63
May 11, 2009 07:14 AM
