Heated Gear
The pants and boots are 1 zone, the jacket and glove are another. You can set percentages of heat in each zone to get your heat comfort level dialed in.
If the bluetooth wrist controller dies while riding, or is missing, it will default to 50% heat, and still work. Takes about 4 hours to fully charge, and lasts about 12 hours per charge.
Comes with a 3 year warranty through harley. The dealership registered it when I bought it, and said it is in system so no need to keep receipt or do anything else for warranty.
Gerbings was bought out a few years back, and they returned to manufacturing here in NC.... I'm not sure if they are still doing so. but something to consider.
Biggest thing to look into is the electrical output of YOUR bike's system....having a tom of heated gear won't be of much use, if you use more power, than your bike produces
The 1 touch system on HD is the bomb, I have it on my Gloves and coat liner.
I am a fairly new in to the heated gear seen (2nd year) so time will tell.
I am waffling between heated grips and gloves (would prefer just liners vs bulky gloves but if grips will do the trick).
It does not get that cold (most of the time) here to warrant headed pants and socks (IMHO) I use soft lowers.
If it gets that cold it is usually very icy and not worth the risk.
Heated pants and insoles are not required on a motorcycle, they exist for ski doo riders who ride in much cooler temps.
What you will need is a warm shell over the liner such as an adv style jacket plus motorcycle textile over pants to wear plus a heated jacket liner and either heated gloves or heated grips and warm gloves.
The heated jacket liner keeps your neck, head, arms and chest warm even with lots of wind cooling with heating elements in these locations. You however need a longer length jacket shell such as an adv style jacket to wear over it and keep wind out. I have a Klim Latitude jacket I use for this. Your cold weather performance will depend a lot on what gear you wear over the liner. Higher cut leather jackets do not work so well as in most cases the zippers and other openings are not wind proof and leather jackets fit tighter than textile touring jackets that have adjustment straps for fit and a lower waist cut. Also it is very important to wear motorcycle over pants over your jeans or a base layer as jeans and other street pants offer no wind protection from cold air. Also you need decent water proof motorcycle boots that go high enough up the leg to keep cold air out. Water proofing like Goretex prevents cold air infiltration.
When purchasing a heated jacket liner you want a relatively tight fit over just a long sleeve T shirt. This is because it heats with body contact. A loose fitting heated liner will not work efficiently or well. Do not wear a heated liner over say a sweater. Insulation goes over the liner not under it. You also need a heat controller for each piece of heated gear you have.
Not all heated gear is the same. Cheaper stuff has fewer and smaller heating elements. AVOID gear with it's own battery packs. It does not get hot enough for a bike rider at 60mph. Instead look for gear that is powered by your bike. It will draw a lot more power but have a lot more heating elements and provide a lot more warmth.
I have ridden for long periods in cold weather (~35F) and never seem to get cold legs or feet. With a well warmed core you get warm blood circulation to the extremities as long as they have a decent amount of insulation over them. Riding at below freezing temps is dangerous due to invisible frost on the road that offers zero traction to motorcycles but is unnoticeable to four wheeled cars.
Pretty much all heated gear use the same coax connectors, and they seem to be the frequent point of failure with the heated gear I have owned. The good news is they can be replaced or fixed. What ever heated gear you buy make sure it has decent warranty coverage (like warm and safe) for several years or it is exceptionally cost competitive (like tourmaster). I own Gerbings but would probably buy a different brand due to their dropping their lifetime warranty.
I ride all winter in the Chicago area and have for the last 10+ years. I have never been uncomfortable - EXCEPT - the finger print area of my fingers. I don't understand why I and a few others that I know of are the only ones with this problem. Anyone else???
Even with the heated gloves and grips. All the heated gear mfg's wire the fingers around the sides of the fingers not top to bottom. So in -30* temps for 3 to 6 hours my fingers get COLD especially at 40 to 50 mph.While riding I have to scrunch up my fingers in order to contact the grips (long skinny fingers). That is the ONLY gripe I have. I also wear a balaklava and a Russian fur hat with ear flaps. Other then the finger tips, I couldn't be warmer.
Is all that gear worth the cost?? Not if you live in the south or don't ride in the winter or not very often. If every weekend = YES!!!!
TIP: In the snow belt = don't forget to spray down the bike with S100 Corrosion Protectant. Worth it's weight in gold.
I get my monies worth from the bike by not storing it for 5 to 6 months every year.
Also I have ridden in the teens and my feet used to get cold. I actually had to get a hotel room on my way home once because my feet were so cold. The heated socks work exceptionally well.
