Heated Gear
warmnsafe.com
I have their heated jacket liner and glove liners along with their wireless dual remote controller. It's an excellent setup.
I find their heated glove liners better than traditional heated gloves as they put the heat right where it's needed. For winter I wear these with a thin waterproof summer glove over them. It avoids the bulkiness of the traditional big heated gauntlets and gives plenty of feel for the bars.
Their heated jacket liner is also excellent. However if I was buying now, I would seriously look at their heated base layer as an alternative because that would put the heat right on your skin.
Heated pants and insoles are not required on a motorcycle, they exist for ski doo riders who ride in much cooler temps.
What you will need is a warm shell over the liner such as an adv style jacket plus motorcycle textile over pants to wear plus a heated jacket liner and either heated gloves or heated grips and warm gloves.
The heated jacket liner keeps your neck, head, arms and chest warm even with lots of wind cooling with heating elements in these locations. You however need a longer length jacket shell such as an adv style jacket to wear over it and keep wind out. I have a Klim Latitude jacket I use for this. Your cold weather performance will depend a lot on what gear you wear over the liner. Higher cut leather jackets do not work so well as in most cases the zippers and other openings are not wind proof and leather jackets fit tighter than textile touring jackets that have adjustment straps for fit and a lower waist cut. Also it is very important to wear motorcycle over pants over your jeans or a base layer as jeans and other street pants offer no wind protection from cold air. Also you need decent water proof motorcycle boots that go high enough up the leg to keep cold air out. Water proofing like Goretex prevents cold air infiltration.
When purchasing a heated jacket liner you want a relatively tight fit over just a long sleeve T shirt. This is because it heats with body contact. A loose fitting heated liner will not work efficiently or well. Do not wear a heated liner over say a sweater. Insulation goes over the liner not under it. You also need a heat controller for each piece of heated gear you have.
Not all heated gear is the same. Cheaper stuff has fewer and smaller heating elements. AVOID gear with it's own battery packs. It does not get hot enough for a bike rider at 60mph. Instead look for gear that is powered by your bike. It will draw a lot more power but have a lot more heating elements and provide a lot more warmth.
I have ridden for long periods in cold weather (~35F) and never seem to get cold legs or feet. With a well warmed core you get warm blood circulation to the extremities as long as they have a decent amount of insulation over them. Riding at below freezing temps is dangerous due to invisible frost on the road that offers zero traction to motorcycles but is unnoticeable to four wheeled cars.
Pretty much all heated gear use the same coax connectors, and they seem to be the frequent point of failure with the heated gear I have owned. The good news is they can be replaced or fixed. What ever heated gear you buy make sure it has decent warranty coverage (like warm and safe) for several years or it is exceptionally cost competitive (like tourmaster). I own Gerbings but would probably buy a different brand due to their dropping their lifetime warranty.
