That's what I did my to bike years ago (Progressive springs). I also added the (Ricor) Intiminators for valving & heavier fork oil. It reduced front end and made a big difference.
Sweet. Figured for 98 bucks why not try it. Definitely was a big difference changing to heavier oil on my dyna. IMO they should come with 15w rather than 10w
That's the only mod I've made to my front end so far. When I did it I used the 15w oil. Didn't really like the way it worked so went back to the stock weight. Much better for my liking.
Running Progressive heavy #11-1546 springs on my Wide Glide; I only weigh 145 pounds and never ride 2 up but the heavy springs were the right choice, also used 15wt fork fluid. Even after I triked the Wide Glide the Progressive springs are up to the task. Follow Progressive's recommendations on the fluid measurement, not the SM...
I read a half dozen books on bike suspension and discovered the stock linear rate front fork springs that came with my Deuce were exactly correct for my weight (200lbs).
My complaint was stock springs with light oil it took sharp bumps great but wobbled like crazy on bumpy sweepers. Plus the brake dive was horrendous.
Heavier oil cured the bobble and dive but rode hard as a brick which hurt my old back and tailbone.
So I put in Intiminators and 2wt oil the softest I could buy.
The Intiminators took out the bobble and front brake dive yet still allowed for a very soft ride over big bumps which is much appreciated.
It is a lot closer to perfect control and I am comparing it to sport bikes that I have owned.
Just a word to the wise in case you are thinking it is a MUST to change your springs.
Mine were fine.
I was being done in by the 70 year old damper rod system that was used on Harleys until they FINALLY changed over to a cartridge valve design a few years ago on certain models.
That old time engineering had such limited control of the front end it really made an improvement with the quasi-cartridge action of Intiminators.
Highly recommended for those that the shoe fits.
It's hard to fathom how the Motor Co. could not have evaluated the simple fix we all did, and the positive results. My buddy has a 2015 RoadGlide and it dives and feels less planted then my bike with those changes. Wake up Harley!
I have been happy enough with them in the past to put some in this week. I can see were you could do better and have used other stuff in the past but subjectively and cost wise I thing that they are worth it for the riding that I do now. I usually put in some aftermarket stuff with first fork oil change--usually two yrs. At 42K you might notice a heck of a difference.
