S&S T111 with Mikuni HS42
Old Nov 11, 2018 | 11:19 AM
Juniorwasp's Avatar
Juniorwasp
2nd Gear
Default S&S T111 with Mikuni HS42
Im currently running a S&S super E on my S&S 111" twincam. I want to switch to the super e out to a mikuni and get away from that carbs two circuit bog. I have heard that the mikuni manifold wont work with the 111's larger jugs. Has anyone run into this? What did you do?
Old Nov 11, 2018 | 04:17 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you had the bike Dyno tuned?
If so did they mess with your air bleed jet?
Have you tried a thunder jet?
Old Nov 11, 2018 | 04:29 PM
Juniorwasp's Avatar
Juniorwasp
2nd Gear
I havent dyno tuned it and also dont think i ever will. I could be wrong here but i dont think its worth the stress on the motor to get it that small amount closer to a perfect tune. The traditional methods have worked well in the past for me, also the motor is only just out of the break in period. I have an older super e with a fixed air bleed(pre 04). I realised that super e's can be drilled and tapped to accept a main jet as an adjustable air bleed inside the float bowl or on the exterior of the carb. I have considered doing this as well as adding a thunderjet. But im having a hard time believing these mods will make the super e more responsive than an HSR42.
The super e is great initially and at WOT. But id like a carb without a mid range flat spot. Im willing to trade some top end HP to get it.
Old Nov 12, 2018 | 02:29 PM
Roadflyer's Avatar
Roadflyer
A HSR42 is a little small for a 111", don't be afraid to go HSR45 or HSR48
The HSR's are light years more evolved than a S&S and about as close to fuel injection as you can get.
Old Nov 12, 2018 | 02:43 PM
Oldskewl's Avatar
Oldskewl
I've ran damn near every carb ever made at some point or another and the Super E is without a doubt the easiest to tune and you can dial it up or down with bleed screw extensions while travelling from low to high altitude. Once you get a E dialed in it's hard to factor in anything else.
Another popular but S&S is the "G" a little harder to tune but once you get it dialed in it's flawless and the midrange is like no other carb. One thing I always look at is what the professionals use for drag racing, you won't find a Mikuni, HSR42 on Progas or pro-mod bike, You will only find an S&S "D" thunder jetted to the moon. FWIW, ride your bike for 1,000 miles then take it to the dyno, not going to hurt a thing putting it on a dyno however, you can hurt it (ruin your entire top end) by running it too rich or lean so it's best to know instead of guessing.
Good luck with your project, nothing wrong with an HSR42 but its not in the same league as a S&S, just my 2 cents.
OS
Old Nov 12, 2018 | 02:47 PM
Oldskewl's Avatar
Oldskewl
What?
Please, tell me more, I'm dying to learn how "evolved" the HSR's are compared to SnS. teach me
Old Nov 12, 2018 | 03:13 PM
Oldskewl's Avatar
Oldskewl
It's almost sacrilege to put a Mikuni on an S&S motor. If the "slide" was such a great engineering improvement you'd think S&S would have made a variant of one but they haven't. I don't see any slides on Top fuel bikes either. It's all about proper jetting. Too bad you live so far away, i'd help you get that carb dialed in.
Zi[ppers."G" thunderjetted. https://www.zippersperformance.com/g...hunderjet.html
Old Nov 12, 2018 | 09:08 PM
PWMORRIS's Avatar
PWMORRIS
I like S&S-dial it in right and it will be good to you. 111" needs a G. Don't quit on S&S-get to work tuning it.
Old Nov 18, 2018 | 12:27 PM
Roadflyer's Avatar
Roadflyer
Originally Posted by Oldskewl
What?
Just about any carb can make good power as long as it's not restrictive and can supply the quantity and proper mixture of fuel /air.
S&S carbs are simple and easy to tune and will make as much power as any of the others, that's why racers like them.
Nobody cares about fuel economy on the track or emissions, rid ability is much more on and off as well.
For a street bike that actually gets ridden, I prefer the better fuel economy (range between fill ups), more consistent mixture (cleaner running, longer lasting engine) and generally better overall manners of the HSR.
If you like Oldskewl, keep it American and simple, I get that and say good for you. If you want something that actually runs better and cleaner as well as making just as much power and don't mind that it comes from overseas, then take the time to properly dial in a HSR.
I myself have left carb days behind me, but I have to admit that my Buddys HSR carb'd evo with cams and heads runs better than my 16 RK
(he had an S&S before the HSR and would laugh at anyone suggesting the S&S was superior).
That's just him, I think if your happy with S&S then great- enjoy.
Old Nov 18, 2018 | 12:57 PM
aces&8s's Avatar
aces&8s
AAAA++++ S&S 111 and S&S carb. They dont call them Super Stock for nothing.
maverickfe
Carburetor Related
54
Apr 3, 2019 07:13 PM
HD4EVR
EVO
Jun 3, 2015 05:13 PM
Asuperglide
EVO
Mar 16, 2010 10:59 PM
3rdgear
Feb 22, 2010 05:37 PM
wydopn231
Jul 12, 2008 07:32 PM
