Wheel bearings?
Old Dec 27, 2018 | 12:34 PM
  #41
multihdrdr's Avatar
multihdrdr
Originally Posted by Imold
I haven't heard of anyone looking inside this latest bearing to see how they're made (plastic spacers or metal cages?) or the grease situation. Someday someone might do it when replacing one and we'll find out.
Long time ago (relatively) ... Metal Cages ... Clear lube
Old Dec 28, 2018 | 12:52 AM
  #42
Imold's Avatar
Imold
I wonder what that clear lube is. All I can find in clear on the internet is food grade, electrical component, and Tri-Flow, none of which are rated for anything as heavy duty as wheel bearings.
Old Dec 28, 2018 | 11:21 AM
  #43
hardheaded's Avatar
hardheaded
Most likely the the crap from the bottom of the Wok.
Old Dec 28, 2018 | 05:05 PM
  #44
1004ron's Avatar
1004ron
Originally Posted by Cullmanco
Hey all, I am about to put a new front wheel on my bike. I am going to have to install the bearings myself and I'm wondering if there is a better brand of bearings out there than HD factory? I bought a nice bearing remove/install kit from ebay and have watched several videos so I feel confident I can install them no problem, just want the best! I want to make sure this is done the best way with best parts available so it will be done right the first and hopefully only time! Thanks for any input and comments about this! Merry Christmas...
I would definately NOT use H-D wheel bearings.
Go to your nearest industrial bearing supplier and get the best high grade available - I used good Japanese ones.
https://www.hdforums.com/forum/softa...s-trash-3.html
https://www.hdforums.com/forum/gener...-bearings.html
Old Dec 28, 2018 | 07:01 PM
  #45
Bob Blehead's Avatar
Bob Blehead
Does anyone have any 'real' mileage experience with All ***** bearings?
Old Dec 28, 2018 | 11:33 PM
  #46
rlh7677's Avatar
rlh7677
Default Bearings
For anyone seeking an after market 25mm bearing, they are nothing more than a pilot bearing used in many applications and made by many manufacturers. Do a search for "25ID X 52OD X 15W " and choose the brand you feel dependable. The Timkin # is Fafnir/Timkin 205PP , NTN is 6205LL and so on. I see All ***** are selling an ABS kit but the HD ABS bearing is not failing at the rate the non ABS are.
Old Dec 30, 2018 | 04:23 PM
  #47
Sparkee...'s Avatar
Sparkee...
I've had 3 ABS bearings fail, never had an issue with the non ABS bearing. Both original ABS bearings and one of the replacements was found to be rough when I had the tire changed.
Old Dec 31, 2018 | 09:04 AM
  #48
tar_snake's Avatar
tar_snake
If I remember right, I only got 10 or 11k on the set I tried. The stock H-D bearings at least gave me 22k.
Old Dec 31, 2018 | 10:45 AM
  #49
maydaymike's Avatar
maydaymike
What are you guys doing to tear up wheel bearings so often? Over 59k on the original bearings in my '14 Street Bob, and they still feel like new.
Old Dec 31, 2018 | 11:56 AM
  #50
NORTY FLATZ's Avatar
NORTY FLATZ
We got defective b alls!
