M8 transmission issues
Old Feb 5, 2019 | 06:50 PM
kpnomad7@gmail.com's Avatar
kpnomad7@gmail.com
Default M8
The thundermax tuner voided my warranty, yes I'll pay for the estimate and figure out if my usual indy will or apply the estimate to the finish up! I ride but been shifting for years, maybe my aim pressure plate was to much and slip of oem clutch would compensate for slight stage power upgrade, live and learn, my wife wasn't happy. But it's one of my bad habits!
Old Feb 6, 2019 | 03:04 AM
Steel Wheels's Avatar
Steel Wheels
Technically the warranty (powertrain anyway) was voided with the tuner, but I’ve got 30k on mine with a CR460 cam, along with the AC, Street Cannons, and PV tuner, and there’s been no problems. Most of the time I’m pretty conservative, but will sometimes hammer down - just because. Sounds like yours was a ‘luck of the draw’ scenario, but if you could prove the gear was improperly manufactured there’d be something to argue about.
Luck with your fix, I wouldn’t want to confront my wife with this either. : )
Old Feb 6, 2019 | 03:53 PM
corliss@bakerdrivetrain.com's Avatar
They are saying your tuner caused the third gear to break? Okay. Let me know if you want a Baker and don't forget your 10% HDforums discount.
Old Feb 6, 2019 | 04:04 PM
MTBIG G's Avatar
MTBIG G
I want a baker. Dont have transmission problems, but still want one.
Old Feb 6, 2019 | 04:14 PM
Oko's Avatar
Oko
kpnomad7 Just bite the bullet and go for the Baker. Maybe spring for the reverse gear too!
Just what are they getting for kidneys & left ********* on eBay these days? I'd think it would cover it.
Old Feb 6, 2019 | 04:38 PM
Warrant's Avatar
Warrant
I would be calling HD for Goodwill on their behalf. Stage 1 on a 107 M8 is not going to fail the transmission. That is a defect in materials from the manufacturer.
Old Feb 6, 2019 | 05:14 PM
I'm sure it was the increased torque from the Thunder Max tuner that destroyed the transmission.
Old Feb 6, 2019 | 05:19 PM
TriGeezer's Avatar
TriGeezer
Where have you been? The EPA decree is that the power train warranty is voided with use of a non EPA compliant tuner. Has nothing to do with what caused the issue.
Old Feb 6, 2019 | 05:56 PM
not a sock's Avatar
not a sock
Originally Posted by TriGeezer
Becausevof a one off failure?
AHHAHAHAHAHAHAHAHAHA!!!
You're funny!!!!!!
He sounds like a SMART individual to me.
Old Feb 6, 2019 | 06:23 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Maybe the OP can find a lab that can do a hardness test on the gear that failed, and keep all your paper work.
