Oil cooler vs. Fans for cylinder
Old Mar 19, 2019 | 08:50 AM
tmac00333's Avatar
tmac00333
Originally Posted by nytryder
Cylinder head temps are what heats up the oil. Lower head temps are the answer to cooler oil. In heavy traffic the twin fan set up is at it's best. On the hiway oil coolers work well. I choose to use neither. My bike has the 110" engine and I live in Fl where air temps on the hiway typically are between 90* and 100* F. My oil temps in standing still traffic jams has never been over 265*. On the hiway my oil temps are usually in the 240*- 250*. I use Amsoil oil and filters and change engine oil every 5000 miles. IMHO any oil temps under 300* in heavy traffic is tolerable for the HD engine as long as a good quality oil and filter is used. Not necessarily amsoil just a good synthetic oil and filter. I am prepared for the bullshit to now begin flowing...
Wow, wish I could say the same. I have the 110 too and in standing still traffic jams can hit 300 in hardly no time at all. I've had mine north of 300, up to 320 and 330. I live in Florida too. I also use synthetic. My highway temps are similar to yours, and change mine every 5,000 miles. Wonder why there's such a difference.
Old Mar 19, 2019 | 04:47 PM
bklynbob's Avatar
bklynbob
Have you ever sent your oil in for analysis?
Old Mar 19, 2019 | 06:07 PM
Zoider's Avatar
Zoider
Originally Posted by 1 2 many
what did the temps drop to ?
I can't remember and it's in the shop for service. I'll check the head temp when I bring it home.
Old Mar 22, 2019 | 12:18 PM
nytryder's Avatar
nytryder
I have not. I may do that in the future. My oil when drained has no burnt smell or a watery look when draining. Oil pressure is virtually the same as new when drained. It is a good idea to send in oil samples once in awhile. Amsoil states their oil is good for twice the recommended drain interval but I stay with the 5000 mile as per HD. Most good quality synthetics are good for 400 degree temps little problems. If your oil gets that hot you already have some serious problems. Personally I see little need for oil coolers or fans, but most certainly have no problems with anyone who chooses to do so. My bike is a 110" and a lifter change is in the future. Other than that I see no reason to doubt any long term problems caused by high oil temps. I hope this helps in some way.
Old Mar 22, 2019 | 12:29 PM
nytryder's Avatar
nytryder
My bike is twin cooled, that could be some of the difference. Also my temps are taken from the oil pan. It is also a 2015 Twin Cam. The highest temp I have ever had was 267* after sitting at a dead stop 15 minutes. Both fans were blowing like hell during that time. What are you using to measure your oil temps?
Old Mar 22, 2019 | 01:32 PM
1 2 many's Avatar
1 2 many
That's what I would like to know what's being used for oil temp reading? My powervision has two temp readings one is engine temp/ which I believe is the sensor in the front head. and the other is head temp. Were is the other sensor at or it just a %off the engine temp
Old Mar 22, 2019 | 01:48 PM
tmac00333's Avatar
tmac00333
Good questions. I have Powervision gauges mounted to my bars. I have engine temp on one of them. I also have an oil temp dipstick which appears to be fairly accurate.
Old Mar 22, 2019 | 10:35 PM
1 2 many's Avatar
1 2 many
how much difference is there from oil temp and engine temp?
Old Mar 23, 2019 | 06:35 AM
Mchad's Avatar
Mchad
Should be substantial. The engine is the source of the heat, and the oil carries it away. Even w/o any coolers, the oil pan is a significant source of oil cooling. A lot of surface area for heat exchange.
On the very hot running 110SE motor on my old LRS, I had a fan assist oil cooler and love jugs mighty mites. Before I did either, I saw engine temps break 300 in summer traffic, and oil temps approaching 270. I want too worried about the oil temp since I ran red line which could take 270 all day long and ask for more.
However after installing the two, engine temps dropped a good 30 degs and oil temps never really broke 240-250. Personally, I like my oil to be above 220, to make sure it’s hot enough to boil out the water that gets in it as a result of the motors combustion.
Old Mar 23, 2019 | 08:06 AM
tmac00333's Avatar
tmac00333
I've been focusing on the gauges lately, but the times I've checked both, oil is cooler than the engine by anywhere from 10-30 degrees. It also cools down slower.
Huggerbugger
Jan 6, 2024 02:35 PM
ConfuciusSay
2014-2024 Touring Models
11
Nov 9, 2015 05:42 PM
Bart van der Meulen
16
Aug 13, 2015 05:48 AM
texas725
Mar 24, 2007 11:45 AM
antalamo
Dec 15, 2006 09:14 AM
