Oil cooler vs. Fans for cylinder
Old Mar 2, 2019 | 09:46 PM
ShadowforNow's Avatar
ShadowforNow
Default Oil cooler vs. Fans for cylinder
If a person could put an oil cooler on their bike or fans for the cylinders (like love jugs), which is better? IIRC, an oil cooler with a fan lowers the oil temp by about 20 degrees. The fans for the cylinders cool the cylinders and heads but I don't recall if they lower oil temperature.
Old Mar 2, 2019 | 10:50 PM
1 2 many's Avatar
1 2 many
I have the jagg oil cooler with fan . I am sure love jugs and an oil cooler will help keep temps down some.
Old Mar 2, 2019 | 11:09 PM
cdonis's Avatar
cdonis
I run an ultracool oil cooler on my 124 twin cam. Does the job really well. I was going to get fans but I don't need them.
Cooler is between the down tubes, has two fans and a thermostat. It actives at 210 degrees oil temp.
Old Mar 3, 2019 | 10:30 AM
bill from tn's Avatar
bill from tn
I have wards fans on my twin cam and replaced my air temp gage with an oil temp gage. The sensor for the gage is at the bottom of the pan so we can debate if it is an accurate read or not.
That said, my oil temps run around 200F and seldom get over 220F unless in long stretches of stop and go traffic or really hard mountain riding. On a hot day I will see a spike in temps after getting off the interstate while sitting at a light on the ramp but the fans keep the temps from spiking.
A big difference is as soon as I start moving the temps drop quickly. Before the fans, it would take a long time for the temps to drop.
A fan assisted oil cooler should give similar results. Anything to get the heat away from the oil.
Old Mar 3, 2019 | 12:50 PM
470004's Avatar
470004
Just my 2 cents; Fan.
Old Mar 3, 2019 | 06:02 PM
Tarkus60's Avatar
Tarkus60
Just my 2 cents oil cooler.......
Old Mar 17, 2019 | 01:01 AM
wagtenor's Avatar
wagtenor
Personally use both love jugs and jaggs oil cooler with fan on my 2016 Low Rider S. Really keeps the 110 cool 😎.
Old Mar 17, 2019 | 01:09 AM
CHHBadkarma's Avatar
CHHBadkarma
I have oilbud cooler on my 110 cvo breakout. SoCal heat and stop and go traffic my oil temp get to 230-235 measured at the tank.
After highway it is a bit under 230. Vastly improved from when I did not have it.
I had planned to do the oilbud in combination with fans for stop and for traffic, but these temps are good enough for me
Old Mar 17, 2019 | 01:10 AM
gamble71's Avatar
gamble71
Oil cooler.... fans always looked like a cheap remedy for bad engineering
Old Mar 17, 2019 | 10:11 AM
MRFREEZE57's Avatar
MRFREEZE57
air movement across the engine always helps cool it, that is why all small engines as lawn mowers, chain saws etc have fins on the flywheel to move air across the head and cylinder.
