Total complete brake failure! Read!!!
Old Oct 22, 2019 | 07:33 AM
  #141
Duracell's Avatar
Duracell
Originally Posted by TSheff
Vapor and air DO compress - that why they are no good in a hydraulic system. Liquids do not compress or have extremely low factors.
I have corrected that statement in my post.
Thanks TSheff
Old Oct 22, 2019 | 07:34 AM
  #142
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by Uncle G.
When I had my Evo I knew exactly how to take care of it and did it all. This new bike is way too complicated for me and I find at my age I have no desire to deal with it. Not only that but it seems like the bike fights me at every turn and even the most routine service tasks seem to be designed to frustrate the owner and force you to take the bike to the dealer.
Sad fact is I just don’t like my ‘19 Heritage well enough to be willing to deal with all that.
What's really f**ked up is after 40 plus years being an avid harley mechanic I feel the same way about my 17 Road King. While it's a great bike it's a pain in the *** to do anything serious with it mechanically, just getting to the battery is a wrestling match. As you say at this age I'm getting less than inclined to deal with it past trivial stuff.
Old Oct 22, 2019 | 07:47 AM
  #143
Zerk's Avatar
Zerk
One reason I buy Harley is easy to work on.
Originally Posted by mmancuso
This.
ABS has nothing to do with the hydraulics of your brakes. It's nothing but a system that applies and controls braking more finely and consistently than a person can. If it fails 100%, you're left with brakes as they would be if you never had ABS.
Pedal all the way to the floor? I'd be asking where all of the brake fluid went? Moisture content? Water does not compress, so I'm assuming that they're saying that above a certain water content, the brake system's seals fail.
I got to think it was a brake failure due to fluid. Not abs. That is what makes sense to me.
I never saw when was last time he rode it. Though it's not that old even if he didn't. What I would like to really know about, how were the brakes working earlier in day, and far he got that day. I think these are important questions that have not been answeted.
Old Oct 22, 2019 | 08:05 AM
  #144
NORTY FLATZ's Avatar
NORTY FLATZ
If the OP has had the bike for "10 months," and he's done 10,000 miles with it, then he's a regular rider.
My HD has ABS, (much to my shagrin.)
Thinking about removing the unit, and drilling a straight thru pathway for the fluid, then replacing. This way, the ECU/PCM or any other tattle tale electronics won't see that it's been bypassed or removed. I don't want/like CEL's.
But, I DO want brakes everytime I want them...
Old Oct 22, 2019 | 08:12 AM
  #145
hellonewman's Avatar
hellonewman
I don't mind that things are getting more complex because the flip side is they also require less attention. My F150 needing an oil change every 10,000+ miles and a rotation is tough to argue with. I need a bore scope to find the turbos but I don't care because they don't need service. I would rather have that than a clunky old F100 with an oil leaking straight six that couldn't pull a sick ***** off a toilet. Growing pains aside, the M8 is better in every measurable way to anything before it and we have technology to thank for that.
Old Oct 22, 2019 | 08:16 AM
  #146
hellonewman
You could bypass it with hard lines or even have flex lines made to go around it and leave the ECU part on the bike, use the HCU as a door stop in your garage.
Old Oct 22, 2019 | 08:19 AM
  #147
Uncle G.'s Avatar
Uncle G.
I think Harley's engineers haven't figured out just where the fine line between "clever" and "stupid" is located yet.
Old Oct 22, 2019 | 08:20 AM
  #148
stixvrad's Avatar
stixvrad
Parts of what the dealership said ( as relayed by the OP) makes little sense. Maybe the OP can clarify? " First, the rear brakes were completely and utterly gone. The Front brake had about 10% (estimated obviously, but yeah.)"
I'm assuming by "gone" that means pad wear..So in 10K miles, the rear pads are worn to almost nothing as well as the front? I'd need to see those pads if it were me. Second, even IF the pads were worn bad, and assuming your brake fluid level wasn't so low that you actually had air in the system now, as long as it wasnt metal backing plate contacting the rotors, youd still have stopping power since the fluid takes up the space created by pad wear. The dealer is suggesting the lack of stopping force was due to the water in the system (5%)??
I may be wrong but if the pads were so worn as to prevent normal braking force being applied, the ABS wouldn't activate because the wheel speed sensors would never "see" the wheel stop . I dont think the OP is wrong, I am saying the dealership is nuts.
Old Oct 22, 2019 | 08:33 AM
  #149
skratch's Avatar
skratch
we keep hearing 'Harley engineers', but I have to wonder, how much of this is on Harley and how much is on bosch?
@stixvrad when he says, front brake at 10%, he isn't referring to the pads, he's referring to the operating efficiency.
Old Oct 22, 2019 | 08:36 AM
  #150
Phil13's Avatar
Phil13
More like how much of all this is a figment of the OP's imagination?
