Total complete brake failure! Read!!!
Old Oct 22, 2019 | 08:46 AM
  #151
stixvrad's Avatar
stixvrad
Originally Posted by skratch
we keep hearing 'Harley engineers', but I have to wonder, how much of this is on Harley and how much is on bosch?
@stixvrad when he says, front brake at 10%, he isn't referring to the pads, he's referring to the operating efficiency.
Perhaps.. But when I read " First, the rear brakes were completely and utterly gone" .. I take "gone" as meaning gone not ineffective. Or the line should have been " The rear system had completely failed"
I'm not trying to be argumentative but if the efficiency was what they were referring to , "failed" , "hydraulic failure", inoperative" would be a word used, not "gone".
Maybe the OP just had an idiot as a service writer who cant translate mechanical conditions into words.
Old Oct 22, 2019 | 08:48 AM
  #152
Since 1968's Avatar
Since 1968
Hey OP, I would like to hear more details about what was done to repair the bike. New ABS module? Pad replacement? Bleed brakes and go? We're missing some details that would be helpful. Any chance you can detail out what the dealership did to get you back on the road?
Old Oct 22, 2019 | 08:52 AM
  #153
Goose_NC's Avatar
Goose_NC
we keep hearing 'Harley engineers', but I have to wonder, how much of this is on Harley and how much is on bosch.
Engineers design it. Accountants reduce cost to sell it. Wether reliability or usability suffers doesn't matter as the lawyers say the profits will exceed the liability.
Old Oct 22, 2019 | 11:13 AM
  #154
mmancuso's Avatar
mmancuso
Originally Posted by Phil13
Yes you can compress water, it does take a lot of pressure, but it will compress. Trying to lay the ghost of Harley's 2008 - 2011 ABS debacle on this site is like trying to plait snot.
Only very slightly, and under tremendous pressure. For all intent and purpose, it does not compress.
Old Oct 22, 2019 | 11:17 AM
  #155
mmancuso's Avatar
mmancuso
Originally Posted by ohioflhs
It would be nice if it failed safe as you describe. It does not! It fails unsafe and therein lies the problem. You have NO brakes when a HD ABS fails.
I suppose it depends on the type of failure (keeps your pedal and grip disengaged), but if true in any situation, then yes, it's a **** poor design.
Old Oct 22, 2019 | 11:29 AM
  #156
Bluesrider.df's Avatar
Bluesrider.df
Originally Posted by hellonewman
Im not sure what the protocol is on a bike but on a car when you start it, the ECU does an electrical test (you need to move the bike to complete this test) and turns off the light if theres no fault found on that side of the system. Once rolling it'll cycle the hydraulic pump and I believe the spool valves but you don't feel this because your foot isnt on the brake when it does it. You could hear the pump do this on older fords when I was a Ford tech. Makes me think that regular exercising of the HCU on cars and trucks could be the difference if HD doesn't do this simple blip of the hydraulic side. Now maybe it does do this, a HD tech would know for sure.
I would love to know if the valves actuate at start up. It seems like this would be a great way to prevent things from seizing up.
Old Oct 22, 2019 | 12:49 PM
  #157
barneyboy's Avatar
barneyboy
I'm thinking you could feel a slight pulse in the brake lever/pedal at startup if that were the case. I can feel the pulses during an ABS event. Never felt it at startup, but if it was just one pulse initiated by a system check, it may be undetectable.
Old Oct 22, 2019 | 04:43 PM
  #158
TSheff's Avatar
TSheff
Originally Posted by Duracell
I have corrected that statement in my post.
Thanks TSheff
I knew you knew that - but didn't want it to lead someone else the wrong way.
Old Oct 22, 2019 | 05:03 PM
  #159
Zerk's Avatar
Zerk
Originally Posted by stixvrad
P
I'm assuming by "gone" that means pad wear..So in 10K miles, the rear pads are worn to almost nothing as well as the front?ts.
I thought he meant the lever or pedal went down all the way. If it was just pad wear, I don't see why we would be discussing this. That would be riding style or bad pads. Plus that would not just fail that minute, I would guess.
I don't mind that things are getting more complex because the flip side is they also require less attention.
I like harleys cause I can work on them. But I hope time marches on and ends up like my truck. You shouldn't touch it other than maybe pads for 100k. I do lots of highway riding. If bikes get that, way I suppose I would be ok bringing in for work.
Old Oct 22, 2019 | 05:05 PM
  #160
Zerk's Avatar
Zerk
Originally Posted by Goose_NC
Engineers design it. Accountants reduce cost to sell it..
True. There used to be shirt shold in jap catalugues, if they had as many engineers as lawyers they would have a better bike. Always thought that was funny.
Originally Posted by Since 1968
Hey OP, I would like to hear more details ad?
WTF do they go?
