Total complete brake failure! Read!!!
Old Oct 23, 2019 | 12:10 PM
  #191
fxdup's Avatar
fxdup
An ABS failure should only mean an ABS failure, not a total brake failure.
This **** poor design needs to be made heartier, even if the maintenance is neglected.
Glad I don't have ABS. I don't want or need it.
Old Oct 23, 2019 | 01:11 PM
  #192
Since 1968's Avatar
Since 1968
Maybe the design flaw has been corrected. I've looked here and on the web for cases of complete brake failure and apart from this month's report of an '18 Heritage there just isn't much out there that I can see. Maybe the 'Dot 4 Platinum' contains a corrosion inhibitor and its been provided in our ABS bikes since 2012? The '08-'11 recall included a brake flush that changed the fluid to the Dot 4 Platinum. I haven't found evidence of a part upgrade for the ABS module itself, but maybe that's been done too. I'm not expecting a press release from the Motor Company since having a fix implies they had a problem. One thing I did see on the web were some class action lawsuit firms looking for clients. It appears there are active cases in four states.
Still looking for better details on the recent failure; what was found & what was fixed.
Old Oct 23, 2019 | 01:37 PM
  #193
skratch's Avatar
skratch
Originally Posted by Brewmany
I found it odd that the OP stated that the dealer was going to charge him $150 to fix the problem. It was not mentioned that the dealer was giving any discount on the repair.
I'm not sure what they could do for such a low price. At the dealers around here that'd get you an hours labor and a VERY inexpensive part.
a brake bleed/flush?
Old Oct 23, 2019 | 01:49 PM
  #194
Dynamick's Avatar
Dynamick
The Platinum brake fluid was introduced around the same time the 08-11 recall was issued so no way it could have been OEM equipment back in 2012.
Even though the part # for the ABS module didn't change, I suspect the module itself did. Harley probably realized there was a serious potential problem with the earlier module and didn't change the part number as a CYA move.
Old Oct 23, 2019 | 04:37 PM
  #195
99Birdman's Avatar
99Birdman
I suspect you are right. The DOT4 Platinum is supposed to have a chemical change which reduces the tendency to gel but, as you said, it wasn't introduced until the recall. Harley probably changed the material for the valves in 2012 to something less prone to be affected by the gelling but, didn't change the part number since that would be admitting they had a problem beyond customer maintenance. Not that the dealer would tell you but, they may have also recalled all the older model ABS module from dealer parts shelves and replaced them with the updated version leaving only those in installed base as a liability exposure which they covered with the recall.
Interesting that, if a 2008-2012 customer changes his own fluid down the road using a DOT4 different than the Platinum, he may apparently still have a problem?
Old Oct 23, 2019 | 04:47 PM
  #196
Harlie Rider's Avatar
Harlie Rider
CYA???
How about SOA; as in "Save Our Asses"
Old Oct 23, 2019 | 05:13 PM
  #197
barneyboy's Avatar
barneyboy
Originally Posted by nazgull2k1@yahoo.com
First off.. yeah, Ive literally had NOTHING but problems with HD since I bought the first one.. this is my 3rd bike in 2 years. 2 of them "brand new."
For starters.. this is my 3rd heritage .. in a row.. in less than a year. Yes, you read that 100% correct. In less than a year, Ive gone through THREE Heritage Softails.
In my opinion, the OP has zero credibility.
Old Oct 23, 2019 | 05:16 PM
  #198
Zerk's Avatar
Zerk
Originally Posted by Goose_NC
Just another example of Harley using technology that has been successful for many years with other manufacturers. But when Harley introduces it they manage to screw it up. Just because they want to make it "Harley" and proprietary?
Sheesh.
I wonder the same about the primary chain tensor. WTF is that? Did they just not want to pay to use an exising one?
Originally Posted by rosefromashes
This sequence of events seems odd to me.. Do you often use both front and rear brake until you come to a complete stop then, click, click, click, click, click down from sixth into first?
I dunno. In an emergency, I start braking, clutch in, shift. In a normal stop, I may have the clutch in and coast to a stop, catching up with my shifting as I slow. Ya its not perfect, but when I know I am coming to a dead stop, I am not as worried about being in the right gear.
Originally Posted by Duracell
Why do you keep bringing this up? The difference is a slight chemical difference in the make up rendering a higher boiling point in the DOT 4. What makes you think DOT 3 would have reacted any differently then DOT 4 in the OP's bike.
id/
The reason I ask this, is most people rarely flush the fluid in cars with ABS. Certainly not every 2 year. Is the difference that cars have so much more fluid? Though more fluid more moisture. I don't know the answer, I just wanted to know why dot 4 and not dot 3 that cars use. Dot 3 is nice get it every where. Dot 5 is PIA, never looked for 4.
Old Oct 23, 2019 | 05:23 PM
  #199
Zerk's Avatar
Zerk
Going through so many bikes does raise a question. But you see more people than I understand doing it. It boggles my mind at the money pissed away by people trading in bikes so fast.
Some I don't think really like bikes, and think if they get the other model, they will be comfortable and enjoy the ride. Granted many of them complain abuout a sore back and just go back and forth between softails and dynas.
Ya I find it weird. But if he really wanted to hate Harleys, why spend so much money? Unless you think he didn't. I havn't followed his progression here to know.
But I would think it would be semi easy to google people who have had failures like this or members, if it is how Harley brakes fail. It just blows my mind that harley might put out a bike with brakes that if you don't flush the fluid willl just fail out of nowhere. I can see a decrease in braking, but to just fail, sees dangerous and illogical to produce. But I dunno.
I don't buy the arguement that if you don't do your brake flushes exactly on time that you deserves this, as some seem to think. I don't know when it rolled out of the factory, but it wasn't 5 years old. IMO if they say 2 years, they should have a safety factor built in.
Old Oct 23, 2019 | 05:25 PM
  #200
Tarkus60's Avatar
Tarkus60
I call Bullshit
