Probably the wrong forum, but I need quick help
Old Jul 21, 2007 | 05:22 PM
ettev's Avatar
ettev
Default Probably the wrong forum, but I need quick help
I'm trying to replace a starter on a 2003 Wide Glide. I have the battery and battery box off the bike and the 2 allen bolts that mount the starter are out. The battery cable connections are off the starter as well. Should this thing just slide out of the engine case from the right hand side? It's hung-up and it feels like whatever it's hung on is spring loaded. Do I need to pop the left side case cover off to remove the starter is it just bound up on the flywheel? Is pulling on the starter to free it or dislodge it a bad thing? How the hell does this come off the bike?
Old Jul 21, 2007 | 07:44 PM
Lpye's Avatar
Lpye
Default RE: Probably the wrong forum, but I need quick help
I'm not sure what kind of engine you are working on, The evo's have a bolt that goes throught the shaft. You have to remove the primary cove to get to it..
shovelhead716
Shovelhead
13
Jun 30, 2020 07:56 PM
FL-kruzen
Nov 1, 2013 04:35 PM
michael of North Platte
Shovelhead
May 14, 2012 12:27 PM
ettev
Aug 12, 2007 06:28 PM
ettev
Jul 21, 2007 06:02 PM
