How critical is this to replace?
Old Jul 22, 2020 | 09:08 PM
gpeade's Avatar
gpeade
Default How critical is this to replace?
Was spray waxing my EG out in the dimly lit garage and managed to break the little rubber vent tube off the top of the chrome tranny cover. How critical is this to replace? I can see maybe water getting into it if I sprayed directly at it with a hose but beyond that do I really need to worry with it?
Old Jul 22, 2020 | 09:12 PM
Zerk's Avatar
Zerk
Not if it stays waxed, in garage. Why not just replace it? Skip buying cosmetics rest of month, and you will save enough money
Old Jul 22, 2020 | 09:17 PM
hardheaded's Avatar
hardheaded
Replace it, it points downward for a reason.
Old Jul 22, 2020 | 09:55 PM
monkeyboy22's Avatar
monkeyboy22
If you're going to replace the vent hose, which I recommend, you might need to get a top cover gasket too.
Old Jul 22, 2020 | 09:57 PM
Zerk's Avatar
Zerk
that's a different thread.
also how did he break it waxing?
Old Jul 22, 2020 | 10:17 PM
Screamin beagle's Avatar
Screamin beagle
How does a rubber hose break? More than likely it just fell off. Get some more lighting and take a look...probably go back on as easily as it came off
Old Jul 22, 2020 | 10:22 PM
hardheaded's Avatar
hardheaded
If it;s old enough it's most likely dry rotted.
Old Jul 22, 2020 | 10:51 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I'm wondering just how much could it cost to replace it? Gotta' be less than a hundred dollars!
Old Jul 22, 2020 | 11:04 PM
Modo's Avatar
Modo
https://partsfinder.onlinemicrofiche...ING%20W/%20PAN
Like item 18? It's $4 lol
Old Jul 23, 2020 | 06:14 AM
dickey's Avatar
dickey
If it wasn't important, the Co. wouldna put it there. You know how cheap & cost cutting THEY are!
