BCM malfunction
Old Sep 10, 2020 | 01:05 PM
Erzsebet's Avatar
Erzsebet
Default BCM malfunction
Hi, I have a Harley Davidson 2014 fatboy lo. I cannot start the engine as the following error message appear.
B2121: starter output open/BCM malfunction. Does anyone have any idea how I could solve this problem? Thanks
Old Sep 10, 2020 | 01:26 PM
Erratikmind's Avatar
Erratikmind
Sorry, no help here. When I saw BCM malfunction, I thought it was firearm related.
Old Sep 10, 2020 | 01:37 PM
WP50's Avatar
WP50
ˇ B2121 - starter output open/BCM malfunction B2123 - starter output shorted low you either have an issue with the starter relay, starter or the wiring associated with them OR the BCM has failed.
The battery would be associated in the wiring as well. Start with the simple stuff first.
Have you done some work on the bike lately?
WP
Old Sep 10, 2020 | 01:55 PM
Erzsebet's Avatar
Erzsebet
Yes, I guess the problem could be that. I bought this motorbike on March. When I bought I tried to start the bike it ran for a few second then nothing happened. Since then I cannot start it again. When I had started repairing I realized the BCM and RCM modules have different number. BCM original American, RCM is European. Is it possible that after the first start the bike automatically prohibit the next start?
Old Sep 10, 2020 | 02:26 PM
WP50's Avatar
WP50
Maybe.
Does the bike have a security system ?
Will the the engine crank but not start?
Is the battery good?
WP
Old Sep 10, 2020 | 02:31 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Try swapping the starter relay and system relay. That's as simple as you can get.
Old Sep 10, 2020 | 02:32 PM
Erzsebet's Avatar
Erzsebet
It has no security system.
The battery is new.
The engine does not do anything.
Erzsebet
Old Sep 10, 2020 | 02:33 PM
WP50's Avatar
WP50
Try asking your questions on this part of the forum
https://www.hdforums.com/forum/elect...ting-alarm-43/
Only found 2 threads concerning that code, neither had alot of info
https://www.hdforums.com/forum/searc...rchid=50793842
Old Sep 10, 2020 | 02:38 PM
WP50's Avatar
WP50
The battery is new.
Erzsebet
Your gonna have to start looking and test things to see.
What have you done so far? Oh and new battery does not always mean a good battery, not often but it has happened.
WP
If you missed it see post #6
Old Sep 10, 2020 | 11:20 PM
Erzsebet's Avatar
Erzsebet
All lights, oil pump are working. When I press start button there will be this code and the bike do not run.
Thanks for your advices. I try to check the cables and relay first.
