Troubleshooting
Old Sep 11, 2020 | 06:56 PM
Howard N. Ohlstein's Avatar
Howard N. Ohlstein
Stage II
Default Troubleshooting
I have a 2005 fat boy CVO. It has 31,000 miles on it and my brake lights keep going out. I replaced the front switch, and the back switch. They each work for a couple of weeks and then no more brake lights. I know there’s some type of electrical problem, but I have no idea how to figure it out. Does anybody have any information for me. I need my brake lights I live in Florida and people down here animals. I’d like to ride safe.
Old Sep 11, 2020 | 07:39 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A couple of questions. Do you clean the light bulb of finger oil after install? The oils from skin can cause hot spots. Are you buying Heavy Duty light bulbs or the cheapest on the hook? Did you lower your bike to the point the tire is rubbing on the wiring to the tail light? Just some thoughts.
Old Sep 11, 2020 | 07:52 PM
ve9aa's Avatar
ve9aa
Have you put an Ohmmeter on the bulb (when it's out) to determine if the bulb is still good?
Old Sep 11, 2020 | 07:56 PM
RANGER73's Avatar
RANGER73
Go LED
Old Sep 12, 2020 | 01:05 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
If NEITHER the front brake lever nor the rear brake pedal will operate your brake light there's has to be a wiring issue, provided that the bulb is good.
Have a frined stand behind your bike and check to see if the brake light works when you press each lever (pedal) seperately.
If one works the brake light and the other doesn't, you've found the suspect problem.
A "test light" is probably the quickest and easiest way to start checking the bulb socket (while a friend operates the brake lever/pedal) but first make sure that you have a good bulb and use some electrical grease on the bulb's contact points before installing it into the socket and proceed from there.
It may also be a good idea to pull each electrical plug apart (uder the seat) and put some electrical grease on them before re-connecting them.
Sounds like a simple problem that just needs a little TLC.
Old Sep 12, 2020 | 01:32 AM
dickey's Avatar
dickey
Senior has it correct...if you buy an Autozone $2 bulb, they can't stand up to the vibrations & bumps that a bike can cause. Buy the$6 bulb from Harley; you need bulbs specifically designed for a bike. Ask me how I know!
Old Sep 12, 2020 | 07:48 AM
SC_Compact's Avatar
SC_Compact
I had a 2005 Dyna and the rear turn signal stopped working. I bought a new bulb and it still didn't work. I determined the bulb wasn't making full contact with the turn signal. I added a TINY bit of solder to the end of the bulb, to make sure it was getting full contact and and never had anymore issues.
Old Sep 12, 2020 | 07:49 AM
Howard N. Ohlstein
Stage II
Default Thank you
Thank yThank you for your speedy reply I don’t buy the cheapest bulbs but I have not bought the best ones either. My bike has adjustable shocks I ride them with 160 pounds in so I don’t scrape boards when I corner. I will try replacing the bulbs and cleaning them better and see where that goes thanks againou for your speedy reply I don’t buy the cheapest bulbs but I have not bought the best ones either. My bike has adjustable shocks I ride them with 160 pounds in so I don’t scrape boards when I corner. I will try replacing the bulbs and cleaning them better and see where that goes thanks again
Old Sep 12, 2020 | 12:50 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Come and join the Florida Crew in Regional Events, Rides and Road Reports
Old Sep 12, 2020 | 03:08 PM
back again's Avatar
back again
I've had to do this a time or 2 over the years. The socket contacts lose their spring tension.Learned this working on VW lights back in the 70's.
