Stumped
Old Sep 30, 2020 | 03:18 PM
2whlr4life's Avatar
2whlr4life
Arrow
Sorry no help here.
I'm a FatBoy own a 95 FatBoy (FLSTF), ad that sure looks like a FLSTF (FatBoy).
Old Sep 30, 2020 | 03:21 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
I had an '87 FXSTC that I tried to convert to the old "points and condensor" ignition system with bad results.
The crankshaft nose (and lobes) were so out of specs that I could not "set" the points at a consistent gap and within a couple of hundred miles they were destroyed!
I finally gave up and removed the ignition module (from the bottom of the horseshoe oil tank) and replaced it---solving the problem.
I learned later on that when the dealers replaced these ignition modules they were relocating them to the top of the rear fender and under the seat to eliminate the heat source that was coming from the heated oil and the rear cylinder and destroying them.
Old Sep 30, 2020 | 04:21 PM
Huggerbugger's Avatar
Huggerbugger
Vapor lock.
Old Sep 30, 2020 | 04:53 PM
Uncle G.'s Avatar
Uncle G.
The factory must have corrected that a while later. My '94 had the ignition module located under the seat on the frame crossmember.
Old Sep 30, 2020 | 06:13 PM
carlgrover's Avatar
carlgrover
How many miles you got on that thing? The last time my EVO backfired and wouldn't restart, there was a hole in the piston and the entire motor had to be rebuilt. Mine had 89k on it when she gave up the ghost.
carl
Old Sep 30, 2020 | 06:17 PM
smitty901's Avatar
smitty901
I own a 1996 Fatboy and it sure looks like a FB to me.
Old Sep 30, 2020 | 09:19 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Dyna S units have been known to fail, I've replaced quite a few over the years. Get an ULTIMA electronic ignition system, single fire. It's adjustable advance curves will work for any big twin or Sportster. Single Fire will reduce vibrations. Just follow the directions for install AND ya get to remove the stock ignition black box.
Old Sep 30, 2020 | 09:33 PM
Uncle G.'s Avatar
Uncle G.
carl
A compression test would verify that pretty quickly.
LDR
Aug 3, 2019 12:00 PM
jcsurf
EVO
Apr 14, 2017 05:49 PM
badinfluence63
Aug 8, 2008 09:01 AM
SPILF
Oct 1, 2006 10:15 PM
jonhoffers
11
Mar 7, 2006 12:20 AM
