7x 14 Trailer
Old Jan 22, 2021 | 03:19 PM
crocker's Avatar
crocker
Default 7x 14 Trailer
Been talking with a local trailer building outfit that will custom-build me a 7x14 trailer for hauling a couple bikes down south every winter. 1 thing I am undecided on is the axles. I have the option of having twin 3500lb Dexters, or for $400 more, twin 5200 Dexters. Pretty sure I’d never have more than 3000lbs in the trailer (usually only 2 bikes), and the trailer itself weighs 2400 lbs. Is there any value in me getting the 5200’s? The salesman says it won’t ride anyrougher with the 5200’s and is pushing for me to go that direction, but if it rides smoother with the 3500’s, then that’s what I want. Your thoughts?
Old Jan 22, 2021 | 03:54 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Get Torsion Axles if possible. Worth the money for better tire life.
Old Jan 22, 2021 | 04:03 PM
VAFish's Avatar
VAFish
I can't see how heavier duty axles wouldn't ride rougher.
I would personally go for heavier duty axles, just because I know at some point I would put more stuff in it. But then I'd go for a longer trailer than 14' too. At least a 20' Then I could haul 4 bikes if needed.
Old Jan 22, 2021 | 04:08 PM
JAKE 2544's Avatar
JAKE 2544
I had a 7.5 x 14 V nose with twin 3500 Dexters and now a 7 x 23 V nose with twin 3500 Dexters. Both tow beautiful with the 3500’s can't image what you would ever need 5200’s for especially for a 14’ trailer. I have friends with 5 place snowmobile trailers that also run 3500’s.
Old Jan 22, 2021 | 04:39 PM
VAFish's Avatar
VAFish
If your 7x23 trailer weighs about 3,000 lbs empty, 4 Harley Touring bikes with some gear for traveling would add 4,000 lbs and be right at the max weight rating of your axles. If your trailer weighs less you have more wiggle room.
Snowmobiles weigh half what an Ultra Limited does (and thankfully so, it's been a long time since I have ridden one, but I can't imagine burying a 900+ lb machine), so five of them are only 2,500 lbs. If their trailer is 3,000 lbs empty they are only 5,500 total, they don't need more than 7,000 lbs.
If all the OP ever plans to haul is two Harley touring bikes, he doesn't need more than twin 3500 lb axles on his 14' trailer. 2,400 lb trailer, 1,000 lb each for loaded Harley's is only 4,400 lbs. He's got 2,600 lbs of wiggle room before he needs to worry about more capacity.
Old Jan 22, 2021 | 07:32 PM
back again's Avatar
back again
Good advice for tandems. I have a 7x 12 Low Hauler that easily hauls 3 bikes . 2 Softails and a SG . You don’t know it’s behind you it tracks so well.
Old Jan 22, 2021 | 07:42 PM
crocker's Avatar
crocker
Perfect replies. As expected, I’ll just get the 3500lb axles. And yes, they are Dexter Torsion. Next question-
What about lighting the inside? It comes standard with 2 12v dome lights, but they’ll be junk and I’ll want to add LED lighting. Thinking maybe 48” long, 12v tube lights (like the old fluorescent, except LED). Or is strip lighting along the perimeter the way to go? I’m sure 95% of the strip lighting is Chinese junk, so if you’ve got 1st hand experience of bright lights for a cargo trailer, please post.
Old Jan 22, 2021 | 08:00 PM
SMR65's Avatar
SMR65
With 2,600lbs of wiggle room, he could put two more deckers in the 14ft trailer "which is not possible " and still have 600lbs wiggle room. Not sure why u would even think of anything more than the 3,500 pound axles under a 14ft
Old Jan 23, 2021 | 02:24 AM
RiderX's Avatar
RiderX
If you do not mind me asking, what us the trailer going to cost you?
Old Jan 23, 2021 | 04:18 AM
highwayman50's Avatar
highwayman50
I would also suggest you consider a 12' instead of a 14' if all your going to pull is 2 bikes, 12' is more than enough. I also had 3 strips of E-trac built into the floor, on each side and one down the middle. When it's built that way it's actually bolted to the frame, much stronger. Have them mount a spare tire holder on one of the walls in the v-nose keeping it inside. I've never had issue with just the dome lights provided by the way. Just my .02
