Dan, did you install the Kuryakyn Fog Lights 5059?
It's back together and the turn sig work but not the fog lights. Kuryakyn is saying it needs to be a wire run to power the lights, but not much help connecting it, HD either.
No passing lamps prior. The Kuryakyn new ones plug into the existing connection fine, and that gives it the turn signal power. There is a splice wire lead attached that would connect somewhere for the lamps to get power. I just don't know where that wire is.
