Hello,
I'm new to the forum. I attempted to do a search but couldn't find anything. I have a 2006 FLSTCI. No O2 sensors on the exhaust for this year. I live on an island with no dyno tuners available. My Power Vision has two tunes, one from Fuel Moto and one from Dynojet. Neither is very good. Fuel Moto has a weird miss/bog at low RPM and sometimes backfires through the throttle body and has stalled occasionally. The Dynojet map doesn't have that issue but is rough. At low RPM (2000-2300) cruising it sputters and is rough.
That's the background. I guess my question is, is there a place where people share their tunes?
Hello,
Use your PV and do a few atuo tune sessions with it, should be easy work for it.
NLGreasemonkey, I had the same experience as you with an '05 recently, the Fuelmoto tune as OK but needed adjustment I was able try try a few dynojet tunes and one of them seems pretty good now, but looking at the dynojet tunes available for '06 it doesn't look like there are as many tunes as with '00-'05 you could try a few others that may be close to you setup, or you can ask fuelmoto to tweek your tune on their custom tune form HERE , that can take a while though more than a week sometimes.
I don't know of another place that has maps to download from, Good Luck .
Not sure why you have the PowerVision because IMO the DynoJet FuelPak was the tuner of choice back when there were no O2 sensors. I believe the PowerVision needs O2 sensors to work properly. I could be wrong though.
Did the bike originally have O2 sensors and someone changed the head pipes?
