Ape Wobble ??
Old Aug 6, 2007 | 10:24 PM
RazorFXDB's Avatar
RazorFXDB
Default Ape Wobble ??
14" apes on the Bob ...
Developed a wobble when cornering at 75mph or greater.
Any little bump in the road seems to set it off.
I have to be extra careful and really brace the bars.
Has anyone else experienced this.
Only started after I put the new bars on.
Old Aug 6, 2007 | 10:34 PM
darkside's Avatar
darkside
Default RE: Ape Wobble ??
Did you happen to change the stock riser bushing to polyurethane? If not you should have. You also have to take into account that your more upright with taller bars and are going to be fighting the wind more now.(you've become a sail) That's all going to be exaggerated running at those speeds.
Old Aug 6, 2007 | 10:41 PM
suspect's Avatar
suspect
center of gravity has changed.your fulcrum point has been moved so the same amount of pressure on the bars is now multiplied.try not to grip real hard on the bars when doing that manuever.welcome to the world of apes.
Old Aug 6, 2007 | 11:06 PM
RazorFXDB's Avatar
RazorFXDB
ORIGINAL: darkside
Haven't changed the bushings yet. Will that help with the wobble, do you think?
I figured i'd run it with the rubber bushings for a bit and see, but after 1000 km run this weekend
I'm thinkin' I'd like to change 'em out.
Old Aug 6, 2007 | 11:24 PM
darkside's Avatar
darkside
It can't hurt.With taller bars you have more leverage and the stock bushings tend to flex alot. It might be you just need to get used to the new riding position and the wind buffeting? The bushings will help make it more responsive to rider input.Hopeyou get it sorted out .Be safe.
SPRINGER's Avatar
SPRINGER
You basically said what I would have said. I have 16's on my bike and they used to have a little play when I had the stock bushings on. On my last warranty checkup, I told the mechanic about it and they replaced them with the poly ones and it made it a lot better. I also agree about the sail thing. I feel like one also the faster that I go. I feel that it's just part of what a person has to go through if they want tohave apes.
ORIGINAL: darkside
Old Aug 6, 2007 | 11:42 PM
RazorFXDB's Avatar
RazorFXDB
ORIGINAL: SPRINGER
ORIGINAL: darkside
I hear ya both ...
Rode about 300 miles yesterday into a strong headwind for about 225 of those.
Hard on the arms and the neck, but nothing I can't live with.
The wobble on the turns is a bit worrisome tho.
Only at speeds 75 and above while in a turn. Not the ideal place to develop a wobble, to say the least.
Anyway, I'm gonna plan to swap out the bushings mid week and see if it helps.
Like darkside said .. .It can't hurt.
Old Aug 7, 2007 | 12:00 AM
ApeKing's Avatar
ApeKing
No wobble what so ever. 16" Apes on an FLHRS
Old Aug 7, 2007 | 05:59 AM
PapaTravis's Avatar
PapaTravis
I have 18" on my rk custom. I have the stock rubber bushings. I have no wobble at all. If I hit a big bump and pull back on the bars, with force, they will shift down, and I have to force them back to where I want them. I was told the only real way to stop this is to add a couple of set screws. I will, if it ever becomes a big problem. Right now, it is just slightly irritating. I relax my grip when I see bumps in the road, and that has helped. BTW, you have checked your tire pressure, right?
Old Aug 7, 2007 | 07:23 AM
bagga's Avatar
bagga
i see you have spokes. check for loose ones start with the rear wheel.
