axel diameters...
Old Oct 20, 2021 | 03:23 PM
GJB12850's Avatar
GJB12850
Default axel diameters...
I came here looking for the axel diameters what I got from posts 11 years ago was so wrong and misleading... HD used 3/4" .75" up until 2000 then went to a 1" with the sealed bearings then in 2008 went to a 25mm axel diameter... now I believe you cannot use a 3/4" tapered bearing wheel with a 1" axel but the sealed bearings both have the same OD the ID is different so a 2001 axel will be ok with a later model wheel... now My expertise ends at he 2010 models. I believe that's when HD R&D went woke and tried to use every new technology and left what got them here behind...JMHO
Old Oct 20, 2021 | 03:27 PM
sbrmike's Avatar
sbrmike
The sealed wheel bearings come in different thicknesses as well.
Old Oct 20, 2021 | 04:37 PM
nobodyknowsme's Avatar
nobodyknowsme
01 had 3/4" axles. I converted mine to 1" and it wasn't cheap. I am talking about the rear axle which required replacing the swing arm. And Izzo, I let the misspell slide. LOL
Old Oct 20, 2021 | 04:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
OK......
Old Oct 20, 2021 | 05:05 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Just a note. They are axles, not axels.
Old Oct 20, 2021 | 05:25 PM
GJB12850's Avatar
GJB12850
did you also have tapered bearings on that... IMHO it was changed before you got it as my 01 dyna had 1" id bearings
Old Oct 20, 2021 | 06:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Are you looking for some help with something??
Old Oct 20, 2021 | 07:09 PM
MURPHCC1's Avatar
MURPHCC1
THIS is an Axel........
Old Oct 20, 2021 | 07:31 PM
Stiggy's Avatar
Stiggy
To further confuse the thread, my 2000 FLT had a 1' axle in the front but ran a 3/4" axle in the rear. Both sealed bearings. (Does that help? )
Old Oct 20, 2021 | 08:57 PM
Cobra1's Avatar
Cobra1
My 2000 Heritage has sealed bearings in front and tapered bearings in the rear. Found this on first tire change. It came from dealer with aftermarket wheels so I guess they used what they had. Lol
oh and I believe they are both 1” axles
