Help please
Old Oct 21, 2021 | 09:43 PM
HDGuy7's Avatar
HDGuy7
Stage I
Default Help please
Just inherited this beautiful bike , has some hose leaks, no big deal. I can’t figure out exactly what bike this is I thought a FXWG but when I ordered a oil filter is was the wrong one. I found the right one at autozone and it fits. But still gonna fix the gas lines. Thanks if any of the older guys can help. I have title it says 1985 Harley Davidson. That’s it
File Type: mov
Old Oct 22, 2021 | 05:16 AM
guido4198's Avatar
guido4198
Try taking some pictures and attaching them to a new post. The MOV opened, but all I got was 13 sec. of background sound and no images.
Old Oct 22, 2021 | 05:18 AM
Stiggy's Avatar
Stiggy
Or get us the VIN number and we can tell you what you've got.
Old Oct 22, 2021 | 07:18 AM
ConfuciusSay's Avatar
ConfuciusSay
Your location is identified as Norwood. Is that Norwood NJ? If so, I am around the corner from you. I can take a look at the bike and help you out.
Old Oct 22, 2021 | 09:27 AM
RHPAW's Avatar
RHPAW
1985 is an Evo. Make sure the oil filter is correct (not a Twin Cam one). Just because it fits doesn't mean it's right.
  • TC motors use a 5 micron filter.
  • TC motors are a high pressure low volume oil system
  • TC paper oil filters that are more restrictive causing less oil gallons per min usually contain a bypass and a anti-drain back valve.
  • Evo motors only need 30 micron filtering
  • Evo motors are a low pressure high volume oil system
  • Evo paper oil filters don't have the anti-drain back valve.
Old Oct 22, 2021 | 09:23 PM
ieatchickens's Avatar
ieatchickens
Like what was said above, your bike is an Evo.
Jump over to the Evo forum and repost. Bunch of great guys over there and they are pretty damn schmart.
Old Oct 23, 2021 | 04:38 PM
TroubleHead Fred's Avatar
TroubleHead Fred
It is a FXR, which version, I'm not sure. Rear fender may have been changed.
Old Oct 23, 2021 | 06:55 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Base model is FXR, with the EVO motor and does take a different oil filter.
Old Oct 24, 2021 | 05:57 PM
Lessontyme's Avatar
Lessontyme
Like someone else said get the VIN number take it to Harley they should be able to bring it up and tell you exactly what you have.
Old Oct 25, 2021 | 06:04 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Attach a pic here so we can help you.
