Motorcycle Easter Eggs?
Oh yeah, dealer goodies:
1) Can’t replicate that
2) They all do that…
Made a trick dual coil bracket the mounts off the upper motor mount, stamped on it is " Size Does Matter "
On the rear I made a custom dual caliper brake setup running twin PM 4 piston calipers mounted on a custom bracket I designed. It's an eye catcher but the way it mounts the stabilizing arm tucks in along the swingarm. Just in front off the shock on that side is a little stainless retainer tab I made that you really need to get in close to see that has " Nosey F**k ain't yah " stamped on it.
Did another little trick setup for the airpump for the rear shock's , mounts just in back of the kicker cover down low on the frame, on the heat sheild I made is stamped " Blow Job ".
You can kinda see the rear brakes and the airpump in this pic.
Oh almost forgot the points cover is a one off handmade item, was a gift from some boys I knew in Colorado.
last if you look at the front of the tanks you will see a shutoff valve where the cross over tube should be.
There's more but these you can see.
Entertaining when peeps are looking the bike over and stumble across these.
100 0737
I work at a dealership so I know alot of "tricks". (hold down info button to contrast colors, changing pin code, EITMS... BLAH BLAH BLAH..)
Anything you all know that I don't know?
